Speaker system question-Altec Lansing ADA995
  1. Posts : 3
    Windows 7 Enterprise 32bit
    I have a 5.1 speaker system connected to either my PC via the green/yellow/black leads or to my cable box via an RCA to 5.1 Logitech adapter to use the speakers. I understand that the adapter doesn't make the sound from the cable box true 5.1, that's fine. The issue is that to switch from the PC to cable box, I have to turn off the subwoofer and unplug/replug the leads. Is there a way to have two inputs on this computer without blowing the subwoofer, basically? It would be easier to have my computer and PC always connected. Thanks
    What you need is an external switching box that will switch the speakers between your PC's sound output jacks and the cable box's jacks. I don't know if a switching box like that is made.
    If it was just simple two channel stereo, there are switch boxes for that (Radio Shack has or used to have a box for that).
  3. Posts : 3
    Right idea, but since there are 3 leads, I'd only get stereo use out of it, better off just switching between devices. Any other ideas? Wouldn't be surprised if not, probably have to get receiver and non-amplified speakers. Not in the cards for the time being, though.
