Sound issue...new Dual Monitor Setup
  1. Posts : 19,383
    Hi Everyone,
    I recently got a second Samsung SyncMaster 2494HS monitor to match my existing one. These monitors have inbuilt speakers.
    With a single monitor, I connected the audio cable from the audio out jack on my inbuilt sound card to the audio in jack on the monitor - no problems, sound all OK. However, I would also like the sound to come from the speakers on the 2nd monitor - ie. sound from all 4 speakers.
    The question is : how do I do that? I notice that on each monitor there is a audio out jack. Can I connect an audio cable from the audio out jack on the 1st monitor, and connect the other end into the audio-in jack on the 2nd monitor? Or will that just result in sound from the 2nd monitor only?
    Thanks,
    Golden
  2. Posts : 6,879
    Win 7 Ultimate x64
    Better idea if that is what you want to do, connect the second monitor to the rear out jack (black one) and then set it to 4/4.1 in the speaker properties.
  3. Posts : 2,240
    Windows 7 Ultimate 64 bit
    You could also use a 3.5mm adapter. You can get one from you local Radio Shack.
    RadioShack.com
  4. Posts : 7
    windows 7 pro 32 bit (oem) {XP and ubuntu 10.10}
    Simple answer would be to use a splitter. Are you using 3.5mm jack lead(s)?
    Using Audio "out" on the back of a monitor would normally send the sound elsewhere, but you could try it and see.
  5. Posts : 19,383
    Thanks for the replies. I messed around with some jacks and cables, but it does seem like a 3.5mm splitter is the way to go. I'll get one this week and let you know how it goes.
    Thanks again,
    Golden
  6. Posts : 19,383
    3.5mm splitter does the job nicely - thanks all.
