Windows 7 Sound gone after Sleep mode Help
Page 1 of 3 123 LastLast
  1. Posts : 92
    Windows 7 ultimate 32bit
    Hello dear friends,
    There is a weird sound issue:
    When I put my Pc on sleep mode and after wake-up the sound is gone and videos are lagging (1frame per 2 seconds).In device manager, it says all audio drivers are working properly, only restarting the PC fix the problem.
    But I definitely need to use Sleep mode and that sound issue is really annoying.
    Special thanks to helpers.
  2. Posts : 5,605
    Hello Martin,
    Have you tried to update the drivers for your Integrated Realtek Sound device?
    I would have help you find them, but I do not see a manufacturer listed in your specs.
  3. Posts : 92
    Anak said:
    Hello Martin,
    where do I find manufacturer?
  4. Posts : 5,605
    What are we dealing with here, a desktop or Lap?
    You could try typing msinfo.exe into the run Search box and it should show you your specs.
    Or, you could download Speccy.
    EDIT:
    Apologies that should of been Search instead of run
  5. Posts : 92
    EDIT:
    Desktop, gimme a sec ill check it out the manufacturer
    Edit:There's no msinfo.exe in search
    What manufacturer do you mean? Motherboard? I have on board realtek audio and audio draivers by nvidia too..
  6. Posts : 92
  7. Posts : 5,605
    Okay....Try typing System info into search.
    Who built your machine, you or Dell, Gateway, etc. we would also need the model number.
    If you, then we would have to try and locate them by the MB mfg.
    Can you explain why, if you have on-board realtek you also have nividia too?
  8. Posts : 92
    Yes I built my PC, and I really don't know why theres also with nvidia, when I have installed nvidia latest driver it automatically installed HD audio driver..
  9. Posts : 5,605
    Martin check this out. It has a few troubleshooters, and maybe a Fix-It:
    No sound in Windows
    Steve
  10. Posts : 92
    No sound in Windows
    Steve
    Hmm i tried to fix step by step like described in the link, but no results.. I don't get it what the problem could be
