audio driver
  1. Posts : 35
    windows 7 home premium 64 bit
    audio driver
    ok i reformatted windows 7 and now trying to get the latest IDT HIGH DEFINITION AUDIO drivers up to date for my laptop and everytime i download the latest version i can't use my sound i had this before. im currently using old drivers which make the sound in crappy quality someone help me?
  2. Posts : 2,240
    Windows 7 Ultimate 64 bit
    Is it enabled? Control panel, hardware and sound, sound, click recording tab and see if it enabled and set as default.
  3. Posts : 35
    hi
    yea man it's all enabled says audio device is disabled which it's not in device manager or control panel i don't know what to do ive reinstalled lot's etc
  4. Posts : 3,822
    where are you getting the new drivers from..?
    are they recommended by the laptop manufacturer?
  5. Posts : 35
    hi
    yes there from the website made for this laptop ive had these drivers installed before the gay service pack 1 screweed my laptop up
  6. Posts : 2,240
    Ok, what's the make and model # of your laptop?
    Have you tried a system restore yet?
  7. Posts : 35
    .... sigh i just reformatted my computer why would i need to system restore...
  8. Posts : 195
    Windows 7 pro 64 bit
    What is your sound card or laptop ? Windows Update not all the drivers.
    at its worst you can try to use a driver for vista who run in windows 7 in majority of cases.
  9. Posts : 35
    hp g61 laptop and the drivers im using are IDT HIGH DEFINITION AUDIO CODEC
