No sound when connected to TV
  1. kmy
    Everytime I connect my Laptop to my 40 lcd tv I always dont get sound to the tv. I have to play it through my laptop. I have a Sony VAIO, less then a yr old running winds 7 64bit. I use a HDMI cable to connect to my tv. My laptop has Blu-Ray player but I haven't try that to see if there's sound TO the tv. So far, I've just been using a external speaker for playing movies from my laptop to my tv. Thats starting to get annoying. Even in "PROJECTOR ONLY" mode I still get sound from my laptop only.
    I want sound from my TV speakers. What should I do?
  2. Posts : 5,795
    You usually have to go into your Sounds Control Panel and change the output device to the video device...which should show up in sounds (yes, seems odd, but that's how it works). My Dell E6400 is this way, and so was an HTPC I had running. The laptop used an Intel graphics card, but had Intel's High Def audio listed in sounds. The HTPC used a Radeon 4350, and I had to switch to the ATI High Def HDMI audio device.
    Projector Only mode is dealing with visuals only. You'd definitely want laptop sound in that mode, in case your presentation included sound.
  3. Posts : 525
    windows 7 ultimate 64bit
    the new win7 sp1 includes some fixes for hdmi audio devices. also, if you have an nvidia graphics card, you may have to change the resolution. my current driver has the option of 1080p with audio or 1080p without audio. and obviously, check to make sure our system is set to use the correct audio device. (you can right-click the speaker icon next to the clock)
  4. kmy
    I went to "SOUNDS SETTINGS" and it only displays the schemes. Can't seem to find any more sound settings besides of master volume but has nothing to do with OUTPUT. Any more ideas?
    I wonder if it'll work if I use a 3.5mm-to-RCA cable to connect from my laptops OUTPUT audio to my tv's INPUT audio?
  5. Posts : 6,305
    What happens when you right-click the speaker icon and select Playback devices?
    There should be a HDMI (High Definition output) device. If you could provide a pic like the 1 below that'd be very handy.
  6. kmy
    ^...Under PLAYBACK i only have "speakers". Nothing shows up even when I right click & click on Show all device. I think I may have a low end sound card. My Laptop is a SONY VAIO VPCEB15FM. Everything is up to date.
  7. Posts : 6,879
    Win 7 Ultimate x64
    Have the latest video driver installed?
    Sony eSupport - VPCEB15FM/BI - Software Updates & Drivers
    This utility updates the Intel Graphics Media Accelerator HD driver to version 8.15.10.2040 and provides improved HDMI™ compatibility.
  8. kmy
    when I try the driver update it saids I'm all updated but my versions are the following:
    -High Definition Audio Device.......DRIVER VERSION 6.1.7600.16385
    -Intel(R) Display Audio................DRIVER VERSION 6.12.0.3040
  9. kmy
    Just did an autodetect on the Intel website and found I am running version 8.15.10.2040.
  10. Posts : 1
    Windows 7 Ultimate x86
    Under PLAYBACK i only have "speakers". Nothing shows up even when I right click & click on Show all device. My Laptop is a DELL INSPIRON N5010.plz tell me should i do , it drives me crazy...
