"Change Sound Card Settings" Question
Hello,
I do a fair amount of changing the Default and selecting the sound card that I use for various programs.
If I do a search with "sound," the Change Soundcard Settings option appears.
I click on it, and get the small screen that allows one to pick the cards for Playback, Recordings, and the Default one, etc.
No problem here.
Question: is it possible to have the screen show up continuously in the Task Bar, or generate a shortcut for the Desktop that would open it up ?
A bit of a pain to have to do a "Search" each time I want to use it.
Thanks,
Bob
