sound card driver?
  1. Posts : 133
    windows7
    sound card driver?
    my audio device driver is this:
    audiocodec_v680b
    it works correctly in xp but doesnt work in WIndows7.
    what should i do?
  2. Posts : 28,845
    Win 8 Release candidate 8400
    audio
    audiocodec_v680b
    what should i do?
    Hi and welcome to SF
    It would help us if we knew what audio card, and computer you have. if you used that codec in xp you need to find and download a different one for win 7
    Ken
  3. Posts : 133
    windows7
    i search for that but didt find any suitable.
    my pc is a Gericom Humer Advance 2640 DVD+RW.
    16bit soundblaster pro competible + AC 97 CODEC , Micro, Stereo Speakers
  4. Posts : 6,879
    Win 7 Ultimate x64
    From the model of laptop you posted ( Gericom Hummer Advance 2640 DVD+RW) and Googling it, it appears to have the Athlon XP2600+ in it. If that is the correct one here is the spec sheet for it,
    http://download.gericom.com/NOTEBOOK...EET/755CI0.pdf - (direct download link)
    which says it has the VIA 1612A audio chip in it, which is one of Via's older audio chips. The best I can find on Via's site for that is a driver for Vista,
    VIA Arena - Display Drivers
    that may or may not work in Windows 7; nothing to lose as there isn't a Windows 7 driver, and base on the age of things not likely to be.
  5. Posts : 133
    windows7
    this driver is not competible with my pc.
    i tried so much but didnt find my competible sound cars driver.
  6. Posts : 133
    windows7
    help me if anybody can.
  7. Posts : 6,879
    Win 7 Ultimate x64
    VIA has gone and totally re-done their website. Anyway try this one (supposed to be compatible with Vista, so about your only chance as i have a feeling you won't be seeing Windows 7 drivers for that chipset),
    displaydrivers
    After downloading unzip it and have a look in the folder for SETUP.EXE, right click on it and select properties. then click on the Compatibility tab and set it to Vista (not the ones with Service pack beside them), and then see if they will install.
  8. Posts : 133
    windows7
    thanks.
    now it solved
    thanks very very thaks
  9. Posts : 6,879
    Win 7 Ultimate x64
    Thanks for posting back.
