Windows 7: Creative audigy 4 crackling recorded sound HELP :((
15 May 2011   #11
r1kk
Windows 7 x64
my audigy 4 also makes crappling noise like "i am robot" but this issue exist since 7 appeared. under xp my audigy 4 was perfect. after changing to 64 bit win 7 everithing went wrong. I mean on the input side cuz the output is crystal clear still on 16bit 24bit it doesnt matter. I tried danielk's driver but nothing changed.
anyway go to creative forums and have a look what creative says about this. at the end you will sell your card just because the driver is impossible to be fixed for years by the creative enginiers
anyway this hardware is not an old thing. the features of this card is still above the average but creative has the almighty xfi that they can sell if you cant use your older one which is on the win7 compatible list since the stable driver release.
Creative, never again.. - Creative Labs
16 May 2011   #12
borate
Quote   Quote: Originally Posted by r1kk View Post
Creative has a driver for W7 32- and 64-bit, which I am using successfully.
http://support.creative.com/download...wnloadId=11314
You might also check for an updated VIDEO driver - from the card or chip
manufacturer's WEB site.
And, click START, then type "performance" (no quotes).
Test disabling the "desktop composition" item, and see if that affects your sound.
16 May 2011   #13
r1kk
Windows 7 x64
well all my driver was up to date as usual cuz i always try to use the latest. i saw this desktop composition thing writen somewhere else but i didnt think that it may be the problem but it was
and here comes the question what is the connection between this windows service and the soundcard?
i cant belive its working now. god bless you mate!
are u from kazahstan?
17 May 2011   #14
borate
I saw this desktop composition thing written somewhere else but i didn't think that it may be the problem but it was ...
Good to hear, mate. No I'm from The States.
Disabling Desktop Composition kills the AERO look, but that eye-candy doesn't affect much else.
Here, Windows Media Center runs - poorly, with some crackling - unless D.T.C. is turned off.
This is likely due to the elder status of my PC. The P4 with 256 video just isn't up to heavy video demands.
So, there comes a time, if you need more horsepower. ^_^
Creative SB Audigy SE sound problem
Hi, I had a problem with my old sound card. It was not working at all. So i bought a new one Creative SB Audigy SE installed the drivers and everything that was given with the sound card and the sound is really weak. I have all the volume up to 100% everywhere and it''s playing music like it is 50%...
Creative Sound Blaster Audigy FX Sound Card, no playback/recording
Hi, I recently purchased the Creative Sound Blaster Audigy FX and am having problems getting it to actually play any audio or record any sound. I've browsed other threads with similar issues on this board and as such have disabled my motherboards onboard audio in my BIOS settings, have...
Creative Sound Blaster Audigy 24bit Sound Card
I installed windows 7 a little while ago but i cant seem to get a driver that will recognize my sound card. the computer doesnt think its installed correctly but when i was using Xp it was just fine. ive tried another PCI slot but no such luck. all of the drivers i have tried tell me that they dont...
Drivers
Creative Audigy 2 sound issues
While playing a game, listening to music, talking on ventrilo my audio starts getting distorted. The best description I can think of is it sounds like a metallic freaky sound. It last for a minute or so and then it starts to clear up and returns to normal. This happens a couple times per day and...
Creative Audigy LS no sound through S/PDIF
Heey, Recentley I bought the logitech Z-5500, along with a lot of cables. I want to hook up 2 speaker sets to my Audigy LS, my standard speakers and the Z-5500. I connected the standard speakers with the 3 normal 3.5mm jacks. However now I want to connect my Z-5500 to my souncard using the...
