Can't display Sound "Volume" icon?
  1. Posts : 7
    I can't see the volume adjust button on the bottom of the screen (laptop). I check the system on/off for Time, volume, network, etc... and the volume one is dim (can't change from off to on). What I need to do to turn the volume on so I can adjust the sound.
    Thanks,
  2. Posts : 7
    subhadip said:
    Make sure whether you have sound drivers installed or not.
    The sound come out the speaker without any problem and I can adjust with fn-f11 or fn-f12. The problem is the volume icon can't display on the task bar.
  3. Posts : 369
    Might try the following on this link.
    System Icons - Enable or Disable
  4. Posts : 4
    windows 7 ultimate 64 bit
    go to control panel>all control panel items>notification area icons>system icons & restore default icon behaviors.
    Attached Thumbnails Attached Thumbnails Can't display Sound "Volume" icon?-capture.png
  5. Posts : 7
    I already check on this but the volume icon on the notification area is dim (can't turn). Even I choose the restore default icon behaviors but the Volume icon still can't turn on.
  6. Posts : 1
    Same problem, applied win7 "quickpatch" from Microsoft, effect: disaster all icons vanished, all notification area icon checkboxes now BLACK! Tried Restore to last remembered working icons. Success.
  7. Posts : 1
    Windows 7 Home Premium
    I was having that same problem and I logged off and then back on and it was there again. Try that.
