No Audio Devices Installed, Help !~!
  1. Posts : 3
    Windows 7 32-bit
    i recently change my windows from XP to windows 7. my VGA also change to a new one. when i test the sound, i cant hear at all !! i go to the contol panel, and check the sound, its say "No Audio Device Installed". i check again through the device manager, in sound,video it seem High Definition Audio Device (not my audio device) and NVIDIA high definition sound. under the other driver, there a ! icon or Unknown Device.
    im using Simbadda CST 5000 audio device
    Sorry guys for my bad english
    Thx
    Sound Card: High Definition Audio Defice
  2. Posts : 6,305
    Hi, welcome to the forums :)
    You may want to Uninstall the unknown device. Just right-click in Device Manager then select Uninstall. Reboot your machine then allow Windows to try to connect to Windows Update to search for new drivers.
  3. Posts : 3
    Windows 7 32-bit
    i unninstall the Unknown Device and nothing change. its kept coming out when im rebooting.
  4. Posts : 1,524
    Thx
    what motherboard are you using?
  5. Posts : 4
    Win7 Ultimate x64bit
    hello pooch, can you help me? i have the same problem, i will vary much appreciate it if you cold so by help me, thank you.
