Windows 7: No Sound please help
06 Jul 2009   #1
daviezone
windows 7
Hi Guys
Upgraded to windows 7 yesterday and everything seemed fine but when I come to play anything there is no sound. It seems as if it is playing ok and I can see the output volume etc but nothing out of the speakers.
In the device manager the multimedia audio controller had no driver and wont update by itself when I go into the details of this device i get this info in the hardware id.
PCI\VEN_13F6&DEV_0111&SUBSYS_011113F6&REV_10
PCI\VEN_13F6&DEV_0111&CC_040100
I have a dimension 9150 and sigmatel audio drivers seem to be working correctly.
Any advice will be warmly recieved as I have tryed everything in my knowledge(which is pretty limeted to be fair).
Thanks in advance
Dave
06 Jul 2009   #2
Archon
Well, just in case, make sure all the speakers, connections, and knobs are in the correct positions. I'm sure you did this though. Next, click on the speaker button (make sure it's not muted) and click the more larger speaker button above the slider.
You can choose your audio device, and if it doesn't show up, then you know you have a problem. Anyways, look around there and the levels tab.
If none of this works, go to the hardware creator for the sound and download a vista driver. if you got a basic sound option, go to your computer manufacturer's page, and download the basic sound driver.
Your driver is probably not working. otherwise you would be hearing sound.
ADDING ON TO ABOVE: also make sure your speakers haven't gone bust on you. try a different set.
06 Jul 2009   #3
digitalrurouni
Windows 7 x64 Pro
I think it is driver related to be honest. When you say the sigma drivers seem to be working what exactly do you mean because it is sort of contradictory to what you said about the device manager.
06 Jul 2009   #4
daviezone
windows 7
Hi Guys
Thanks for the replys . I have got it going . I downloaded the vista drivers for realtek a97 or something like that and it is away. Not sure what them sigmatel drivers are but they sure did confuse the whle situation.
Thanks again
06 Jul 2009   #5
Archon
Quote   Quote: Originally Posted by daviezone View Post
Hi Guys
Thanks again
Could you give me reputation please?
EDIT: Just press the button that looks like a scale on the post that helped you.
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Distortion sound using onboard realtek sound card on windows 7ultimate
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd...
Sound Control panel takes 2 minutes to open; HDMI sound inconsistent
Brand new Windows 7 Home Premium (6 bit) computer. When I click on the Sound control panel item, sometimes it takes 1-2 minutes to open. But that's kind of minor (although I'd like to know how to fix it), because sometimes the HDMI sound to my HDTV works fine, and sometimes it doesn't work at all....
narrator no sound - and sound vbs file no sound
I tried this file on my other win 7 and it works fine , but I have no sound with this file . and narrator has no sound also .. system sounds and mp3 's / movies sound good ... Ideas . thanks
Missing Sound Video & Game Controller in Device Manager, no sound
Hi Its bit complicated.:D I have 5 year old Compaq Pressario V3611AU notebook with AMD Atholon X2 TK-55 processor. Was using Windows XP and everything working fine. Recently I upgraded RAM to 2GB & processor was changed to AMD Turion(tm) X2 TL-60 2.00Ghz. I installed windows 7 and everything...
