Windows 7: No sound with onboard audio
26 Apr 2011   #11
mallen
Windows 7 Pro 64bit
So should those NVIDIA drivers be there? I thought I only had NVIDIA drivers for video.
26 Apr 2011   #12
Mike Connor
Several, including Windows 7 x64 Ultimate
Quote   Quote: Originally Posted by mallen View Post
So should those NVISA drivers be there? I thought I only had NVIDIA drivers for video.
I would deinstall all of them and reinstall. Multiple driver instances is always a bad idea.
Regards....Mike Connor
27 Apr 2011   #13
mallen
Windows 7 Pro 64bit
I removed all the drivers including the NDIDIA ones. Not sure how those even got there since I got a new board. Reinstalled new drivers. Still no sound but meters are showing music and sounds playing. Checked speakers with my MP3 player and they work.
27 Apr 2011   #14
mallen
Windows 7 Pro 64bit
Ok I solved it. Not sure what I did exactly. Can't say which one of these fixed it but here is the order. I unplugged the speakers. Rebooted. The rebooted in safe mode. Then rebooted. Went to device manager and removed under system devices: 2 high definition controllers. Under sound 4 high definition audio devices and 1 VIA high definition audio. Rebooted. Then windows installed some drivers automatically. Downloaded and installed the latest VIA HD audio codec driver v8.3.00.31.100524 Then booted up the BIOS. There was a setting for front panel audio type. The choices were HD or AC97. I changed it to AC97. Rebooted and the sound was back.
27 Apr 2011   #15
Mike Connor
Excellent. Good to hear you got it sorted out. Multiple driver instances are always a problem.
No sound from onboard audio (Realtek High Defition Audio)
Hey Guys, So here it goes, I normally have my Logitech z-5500 speakers connected to the onboard sound output (green,yellow and black) as well as my Plantronics 780 connected to the front panel USB port. I used to be able to play music through any one without any problems, just had to select...
Onboard Audio - no sound
After discovering that my beloved HT Omega Claro Plus soundcard cannot be installed on my new mb due to the lack of PCI slots, I decided to go with the onboard until I get a new card. I enabled onboard audio in the BIOS, downloaded and installed the latest drivers, went to Control Panel >...
No Sound from Speakers with Onboard Audio
I recently put together a new system with a fresh installation of Windows 7 64 bit. I cannot get sound to come from my speakers no matter what I have tried. I have trolled through all the forums I could find on the subject, and tried every possible solution, to no avail. I am hoping I simply...
Onboard audio and how to get 5.1/7.1 sound via HDMI
I'd figure I've got some time to make a new thread here for members of SevenForums who may have experienced some difficulty getting sound out of their computer via HDMI Locate the SPDIF connector on your motherboard using a 2 pin spdif cable PIN assignment # 1 Power 2 No pin 3 SPDIF...
I have a Sigmatel audio onboard no sound!
I have a Dell XPS 410 with Sigmatel onboard soundcard and I installed the newest drivers that Driver Detective found for me which was IntelĀ® Desktop Board DG33TLĀ Audio: IDT* 92XX Driver But I still have no sound working could somebody please help me to get the sound to work on my computer!!
