Windows 7: No sound with onboard audio
26 Apr 2011   #1
mallen
Windows 7 Pro 64bit
Using Windows 7 64 bit. Have ASUS M4A79XTD board with onboard audio. Everything has been running great. There were no changes or upgrades done yesterday. There was a power failure at my house for a second and when it booted up it asked do you want to start up as usual or in safe mode etc. Ever since I get no sound. I see the audio waves in media player. Also the sound controls show meters moving up and down. I got the latest VIA audio driver. Anyone have any other suggestions?
26 Apr 2011   #2
Sardonicus
Windows 7 Home Premium 64 bit
Do you have the default set to "Speakers"
26 Apr 2011   #3
mallen
Windows 7 Pro 64bit
Yes I have the speakers set as default.
26 Apr 2011   #4
Mike Connor
Several, including Windows 7 x64 Ultimate
Power failures can cause severe problems with various things. It may have killed your speaker amplifiers.
Check to make sure that you have the volume turned up, and not "Muted".
Regards....Mike Connor
26 Apr 2011   #5
Sardonicus
The only thing I can think of, based upon what you mentioned, is that there may be something wrong with the levels.
To check, go to the volume mixer > Playback devices > Speakers > Properties > Levels > Front.
Make sure that the front level is at 100.
26 Apr 2011   #6
Sardonicus
Quote   Quote: Originally Posted by mallen View Post
Yes, ASUS uses VIA, instead of Realtek on your particular board, so the setup is different. Check for additional settings on your VIA control panel, if you have the VIA driver installed. There may be a front volume setting on the control panel that may be lowered or muted. If not, try re-installing the driver from here. VIA Drivers Download - VIA Technologies, Inc.
26 Apr 2011   #7
johnnya
Windows Home Premium 64bit
Hi Mallen and welcome back to the Forum. Sometimes a momentary power fluctuation can cause unexpected changes to Bios setting. Yes I have seen it more that once. On the outside chance, go into your Bios at startup - go to Advanced tab, then the On Board Device Congiguration tab, then Hd Audio Controller and make sure it is set to ENABLED.
Just a shot - give it a try.
Regards
JohnnyA
26 Apr 2011   #8
mallen
Windows 7 Pro 64bit
I checked the BIOS and onboard audio was enabled. I disabled and then renabled it to see if that would help. Below that was a setting I was not sure about.
Eup Ready- Allows BIOS to switch off some power at S5 state to get system ready for the Eup requirment. When set to ENABLED, power for WOL, WO_USB and audio will be switched at S5 state.
Not sure what S5 state is????
Also since the power got interrupted, maybe its "stuck" in some in between mode?
26 Apr 2011   #9
Mike Connor
WOL is "Wake on Lan" ;
Wake-on-LAN - Wikipedia, the free encyclopedia
WO_USB is "Wake on USB":
Universal Serial Bus - Wikipedia, the free encyclopedia
S5 is "Soft Power Off";
G2 (S5), Soft Off: G2 is almost the same as G3 Mechanical Off, but some components remain powered so the computer can "wake" from input from the keyboard, clock, modem, LAN, or USB device.
Advanced Configuration and Power Interface - Wikipedia, the free encyclopedia
26 Apr 2011   #10
Mike Connor
What about these NVIDIA drivers. Should I try deleting these?
Attachment 151424
Use "Driver Sweeper" to remove all old installations before reinstalling;
Phyxion.net - Driver Sweeper
No sound from onboard audio (Realtek High Defition Audio)
Hey Guys, So here it goes, I normally have my Logitech z-5500 speakers connected to the onboard sound output (green,yellow and black) as well as my Plantronics 780 connected to the front panel USB port. I used to be able to play music through any one without any problems, just had to select...
Onboard Audio - no sound
After discovering that my beloved HT Omega Claro Plus soundcard cannot be installed on my new mb due to the lack of PCI slots, I decided to go with the onboard until I get a new card. I enabled onboard audio in the BIOS, downloaded and installed the latest drivers, went to Control Panel >...
No Sound from Speakers with Onboard Audio
I recently put together a new system with a fresh installation of Windows 7 64 bit. I cannot get sound to come from my speakers no matter what I have tried. I have trolled through all the forums I could find on the subject, and tried every possible solution, to no avail. I am hoping I simply...
Onboard audio and how to get 5.1/7.1 sound via HDMI
I'd figure I've got some time to make a new thread here for members of SevenForums who may have experienced some difficulty getting sound out of their computer via HDMI Locate the SPDIF connector on your motherboard using a 2 pin spdif cable PIN assignment # 1 Power 2 No pin 3 SPDIF...
I have a Sigmatel audio onboard no sound!
I have a Dell XPS 410 with Sigmatel onboard soundcard and I installed the newest drivers that Driver Detective found for me which was IntelĀ® Desktop Board DG33TLĀ Audio: IDT* 92XX Driver But I still have no sound working could somebody please help me to get the sound to work on my computer!!
