Windows 7: HDMI Sound problem.
27 Apr 2011   #1
Gilly
HDMI Sound problem.
I've having problems with my sound what is a direct hdmi cable to hdtv from gpu(5770).
When i usually have sound problems i just uninstall the sound devices reboot and job done.
But i've exhausted every idea i can think of to try and fix it thats why i came here for help.
I've updated drivers uninstalled windows update what i installed today before i realised the audio wan't working,can't restore because i turned it off because it always failed anyway .
Could there be a problem with the audio on the actual gpu.
Help much appreciated any troubleshooting solutions etc.
thx
27 Apr 2011   #2
Johnathan Lyman
Windows 7 Ultimate 64-bit
The HDMI portion of your graphics drivers take over sound control when HDMI is used as an output for audio. Consider updating your graphics drivers to the latest 11.4 version (released today) from ATI Radeon.
Please also describe your "audio problem" in a bit more detail.
27 Apr 2011   #3
Gilly
Quote   Quote: Originally Posted by Johnathan Lyman View Post
no playback at all.Yes ,yes i tried everthing like that.I've used hdmi for sound for ages so knew everything what stops the playback.
Anyway i decided to reinstall windows it still wasn't working then miraculously it just started working again very strange.
-SOLVED-
28 Apr 2011   #4
Johnathan Lyman
Might be your card, it might be your cable. I cannot speak to whether audio and video are transmitted on separate pins in the HDMI cable (the first 12 of 19 are reserved for data be it audio and or video but are not specific to either). The easiest way to test is replace the cable. Second would be to replace the card, of course.
 HDMI Sound problem.
Sound not working, Only have HDMI Sound Output, But no HDMI port in PC
Hi there, My sound is not working. I only have a HDMI Sound output. However, I don't have any HDMI Output in my computer. I reinstalled windows a couple of times lately, but i don't know for sure if thats the problem. Right now im using Windows 7 32-Bit, My hardware specs are: CPU: Intel Duo 2...
Drivers
Sound Control panel takes 2 minutes to open; HDMI sound inconsistent
Brand new Windows 7 Home Premium (6 bit) computer. When I click on the Sound control panel item, sometimes it takes 1-2 minutes to open. But that's kind of minor (although I'd like to know how to fix it), because sometimes the HDMI sound to my HDTV works fine, and sometimes it doesn't work at all....
NO SOUND TROUGH HDMI ON ACER AX3400-U3032 and No HDMI Icon in sound se
Had to replace motherboard from authorized acer parts dealer now I get no sound through HDMI port. I did through the original board until it got fried by electrical surge. Can any one help or send me a picture of the inside the same model to make sure all jumpers on the motherboard are in the...
No sound through speakers.Jack not being detected.HDMI sound only?
So I've got a problem,I changed my case 2 days ago and everything went great,all working as it should be.Up until an hour ago,when the lid got stuck in one of the little clips so after a quick bang it went in.But then I lost my picture on both monitors. So I went to investigate,I ended up...
no sound through tv via hdmi, sound plays through laptop speakers (idt
Yesterday I installed a new external hard drive - following the installation - my sound no longer played through my television (video is fine, HDMI connection) and sound now comes ONLY through the laptop speakers. The option for HDMI Audio doesn't appear in the 'sound' menus. I have 'checked'...
