Windows 7: need help like mad going crazy
27 Apr 2011   #21
Mike Connor
Several, including Windows 7 x64 Ultimate
Quote   Quote: Originally Posted by xxadosxx View Post
Sound Cards
ATI High Definition Audio Device
it just saying it cant detect it but it says its enabled and working but it keep saying its not pluged in does it matter if i have a pc audio input in the back of my tv ?
What says it cant detect what? Do you get this error on your PC, on your TV?
If you have other audio inputs into your TV then you need to choose which audio input it should use. It can not use two audio inputs at the same time. It can only use the input which is enabled. This needs to be enabled on your TV.
Regards....Mike Connor
27 Apr 2011   #22
xxadosxx
windows 7 x64
says it cant detect the ati hdmi audio out put and how do u make it choose which one it uses
27 Apr 2011   #23
Mike Connor
What device says it can not detect the ati hdmi audio output? On what screen are you seeing this error?
The TV screen, or your PC screen?
In order to make the TV accept a certain input, you need to use the TV menu.
Svchost.exe Crazy High CPU Usage and Crazy High Memory Usage
There is a serious issue with svchost.exe on my windows 7 computer. My HP Touchsmart 300-1025 has windows 7 64bit installed and svchost is slowing down the computer and using very high cpu and memory usage. It is not a virus or malware. I know the computer is not infected because one the computer...
Performance & Maintenance
Fan runs crazy, track-pad crazy, browser hangs, slow & unresponsive
Hi All, I hope someone here can help me as I can't go on with this crazy machine any longer... My machine is a 2012 Sony Vaio, I've just updated my system specs. What happens is the following: The fan runs for no apparent reason. It just takes off, loud and blowing out hot air even though the...
General Discussion
I get crazy!
Why is IE (regardless of version) changing the . to _ when I download a file (e.g. xxx.exe to xxx_exe or xxx.pdf to xxx_pdf)? The only thing I can do is to restart the Pc. On my laptop I use Windows 7 32 bit and on my desktop I use Windows 7 64 bit. Same error. On my work, I have asked our IT...
Browsers & Mail
New Tab gone crazy
I hope this is an easy question to answer. When I go File --> New Tab in IE9, instead of opening a new tab in my home page, it open to "about:Tabs". IS there anyway to force it open at my home page???
Browsers & Mail
thats just crazy
Whats the craziest thing you've ever convinced your friends about computers. I once convinced my friend he needed a carbureator for his computer, so he could get NOS and overclock it. Google proved me wrong though.
Chillout Room
