Sound help
Page 2 of 2 FirstFirst 12
  1. Posts : 8,608
    Windows 7 Ultimate 32bit SP1
    Don't set the speakers as your default device, try the one below (in your snapshot), or the ATI
  2. Posts : 477
    Windows 7 Ultimate 32 Bit, Windows Developer Preview, Linux Mint 9 Gnome 32 Bit
       #12
    You can take a look at these very recent threads that discuss relevant sound issues with your case. You might see some important info from in there. Good Luck.
    Speakers Not Working
    No Sound from Speakers with Onboard Audio
  3. Posts : 9
    Windows 7 Ultimate x32
    Tried this, did'nt work. i also 'tested' all of the options, but no one worked...
    Looked trough and no one has the same problem...
    My speakers work with the startup sound... so i know that they are not broken.
  4. Posts : 9
       #14
    I just saw this!!!
    with nothing attached to the 3 outputs one of them is still active :O
    i usually use the middle (the black one) to connect my headphones.
    when i look at the computer it says S/PDIF on the one that is active.
    Why is this exit avtice all the time?
    It must be the problem...
  5. Posts : 9
       #15
    BUMP!
    Can it be that i have the wrong drivers? or is it something wrong with the output? something electrical? What do you think?
