No Sound from Speakers with Onboard Audio
Page 2 of 2 FirstFirst 12
  1. Posts : 8
    Windows 7 Ultimate x64 (6.1, Build 7601)
    This is a new build, so dust is a non-issue. I am starting to think it is a hardware issue, as well. However, there is one more thing which may be behind this.
    This is actually the second MSI motherboard involved in this installation. The first one had some non-working USB ports, so I took it back to Fry's and exchanged it for this one. Unfortunately, I can't recall if the sound worked on the first board, because I was focused on the USB ports at the time.
    I did not do a clean install when I got the replacement, because I figured it was the same make and model. Is it possible a clean install would help? I did try a 32 bit Vista installation, as well as a virtual XP installation, and sound did not work on either of those.
    I REALLY don't want to have to make another trip to Fry's, but or looks like I am running out of options.
    Lane
  2. Posts : 477
    Windows 7 Ultimate 32 Bit, Windows Developer Preview, Linux Mint 9 Gnome 32 Bit
       #12
    This was a motherboard exchanged for your first motherboard with broken USB ports, so you are saying this is NOT a brand new motherboard?? So it may have defects.
    So maybe yeah, its a hardware issue.
  3. Posts : 8
    It IS a brand new motherboard, which I got after returning the first one (same make and model) with the non-functioning USB ports. It definitely might be hardware, but I want to rule out everything else before going through the process of exchanging this board yet again.
  4. Posts : 592
    WIN7 Ultimate 64bit
       #14
    Try fiddling with the frequencies
    - like start at basic CD 16bit 44.1Hz
    Then work your way up to 24bit DVD quality etc
  5. Posts : 8
       #15
    Thanks, Neo. Tried that, too. It's looking more and more like a faulty board. I'm starting to get a very bad taste in my mouth for MSI
  6. Posts : 592
    WIN7 Ultimate 64bit
       #16
    Stop spraying then
    Pepper Spray /MSI Chemical Weapon?
    Have you plugged amp/spkr into another 'puta to test?
    Try just with one wire = stereo setup
    Pull the front panel sound connection from your case lead off - see if that changes anything
  7. Posts : 1,114
    Windows 7 Home Premium 64 bit
       #17
    Do you have the latest graphic card drivers for your card, they also have a bearing on sound, also do you have the latest chipset drivers, just some possibilites
  8. Posts : 1,996
       #18
    Have you tried plugging a pair of headphones into the "Line-Out"
