No Sound Output to Speakers or Headphones
No sound output can be caused by several problems. The following suggestions may resolve the problem of no audio output:
Onboard audio is disabled in the BIOS
The BIOS Setup program is accessed by pressing the <F2> key after the Power-On Self-Test (POST) memory test begins and before the operating system boot begins. Go to the Advanced > Peripheral Configuration menu to make sure onboard audio is enabled.
Audio settings in the sound mixer are incorrect
Check your audio mixer software to ensure audio is not muted or the volume level is not turned too low.
The speakers or headphones may be connected to the wrong jacks
Make sure you connect all speakers to the correct jacks. If you connect them to line-in or microphone jacks, they won't work.
Audio drivers are not properly installed
Check Device Manager under the Sound, video and game controllers section for any errors associated with the audio driver. Reinstall the audio driver if necessary.
Audio to back panel is muted if front panel is connected
Check your audio mixer software for a setting that mutes back panel audio if you have plugged headphones into a front panel audio solution. Uncheck this setting to allow audio to both the back and front.
Sound Playback is set to wrong device
In Control Panel > Sounds and Audio Devices, go to the Audio tab. Check the default device for sound playback; there may be multiple selections. Select the desired device, either rear panel or front panel.
