Was there ever a solution to the "No audio output device is installed"
  1. Posts : 7
    Windows 7 Enterprise SP1 32bit
    I've been going on for a month without sound now. Earlier, it used to be a few times a week with sound. Stupid HP laptop.
  2. Posts : 2,009
    Windows 7 Ultimate x86
    Try to get the correct audio drivers from HP
    HP Support & Drivers | United States
    -DG
  3. Posts : 7
    I can't install drivers when the laptop doesn't detect the sound card. Besides, when the sound actually works, installing new drivers doesn't stop the inevitable. I've tried this before.
  4. Posts : 2,009
    It's just the other way around (especially with on-board "cards") The computer wouldn't see the device until it has appropriate drivers.But when you say you tried that already...nvm
  5. Posts : 592
    WIN7 Ultimate 64bit
    check audio is enabled in bios
    (or have you got a separate sound card for laptop - what make is it? in which case you should normally disable onboard sound)
    if device shows in device manager
    In device manager 'disable' the audio device driver with yellow exclamation - then re-enable it. It might kick in.
    Also go into audio device > driver > update driver > 'search auto for updated driver'
    See if that forces a correct install
  6. Posts : 7
    How do I go about checking it in the bios? Also, the sound category doesn't show up at all in the device manager.
    EDIT: found out how. but my bios didn't say a thing about sound
  7. Posts : 592
    WIN7 Ultimate 64bit
    It might mention connexant or realtek in the bios
    Additionally it might be hidden in an advanced menu that requires a special combination of keys to be pressed to reveal
    can you fill out your system specs please
    try this - easier than me posting it No Sound from the Speakers in Windows 7 - HP Customer Care (United States - English)
    Try downloading the Win 7 High Definition drivers direct from realtek site (but can't be certain it's right guess, cos don't know your model of computer yet!)
  8. Posts : 7
    OS Version: Microsoft Windows 7 Enterprise , 32 bit
    Processor: AMD Turion(tm) 64 X2 TL-58, x64 Family 15 Model 104 Stepping 1
    Processor Count: 2
    RAM: 2050 mb
    Graphics Card: NVIDIA GeForce 7150M / nForce 630M, 64 Mb
    Hard Drives: C: Total - 152617 MB, Free - 72084 MB;
    Motherboard: Wistron, 30D6, 81.53,
    The sound card is conexant. I'm 100% sure of it since that's the name I saw of it before this problem started happening. I've also tried the link you posted and it just told me "Hardware changes might not have been detected" And simply refreshing device manager to see the sound card doesn't help since the sound category doesn't even show up.
  9. Posts : 592
    WIN7 Ultimate 64bit
    Processor Count: 2
    RAM: 2050 mb
    Anywhere near your model ? What is exact model number - am I in right country?
    HP Pavilion dv2700 Entertainment Notebook PC series specifications - HP Home & Home Office Products
    Hewlett-Packard HP Pavilion dv2700 Notebook PC F.24
    System Serial Number:
    Enclosure Type: Notebook
    Processor a Main Circuit Board b 1.90 gigahertz AMD Turion 64 X2
    64 kilobyte primary memory cache
    1024 kilobyte secondary memory cache
    64-bit ready
    Conexant SmartAudio 221 3D Sound Blaster Pro compatible sound 16 bit integrated
    Multi-core (2 total)
    Not hyper-threaded
    Board: Wistron 30D6 81.53
    Bus Clock: 200 megahertz
    BIOS: Hewlett-Packard F.24 04/24/2008
    Drives Memory Modules c,d 160.04 Gigabytes Usable Hard Drive Capacity
    There only appears to be an HP Vista driver - try installing it
    If it won't run try installing it under 'compatability' mode
    http://download.cnet.com/Conexant-Hi..._4-177475.html
  10. Posts : 7
    I don't remember where to check for the others but, my laptop is a dv2610(usa)
