Windows 7: Need help with this problem
13 May 2011   #1
wazza
Windows 7 Ultimate x86 (32-bit)
Hello everybody! I need a little help here.
My laptop is HP dv2748TX. I upgraded it to Windows 7 Ultimate from Windows Vista Home Premium like maybe 2 months ago.
So, I've got this problem that annoys me a lot and sometimes pisses me of depending on my mood. That problem is, muting and unmuting by itself for a period of time. I'll be having fun watching YouTube or listening to music on iTunes/Windows Media Player when suddenly it just mutes. That's one problem. There other one is, stopping or pausing a video on its own. e.g. Watching Youtube and it pauses by itself a couple of times and I end up closing the tab. eg 2. Watching a DVD on my laptop on Windows Media Player (or any other player) and it just stops not pause, stop. I would play it again and it would stop again.
My brother told me that it could be the Quickplay/Quicktouch buttons. I don't really know what it is called but Google my laptop and you'll see what I mean by this if you don't know. It's the part above the keyboard where there is Quickplay button, a DVD button, Previous, Pause/Play, Next, Stop, Volume mute, Volume 'slider.' I was thinking, maybe he's right.
I Googled for some solution so the people asks to go to somewhere in control panel or msconfig --> startup and find that Quickplay thing and disable or uninstall them but I just can't find it and I'm sure it's beacuse I upgraded to Win7. I look up at my Windows.old folder and there it was, a folder called 'HP Quick Launch buttons' I deleted the folder but it still mute on its own so I just restore it.
Any solution guys? I really hope that there is a solution for this. I just wanna enjoy listening to music and watching YouTube again.
Thanks in advance!
13 May 2011   #2
DMHolt57
Try going to Hp.com and look in the drivers and support section, see if the Quick Launch Buttons is available under keyboard for your machine.
13 May 2011   #3
wazza
I went to Drivers & Software downloads and apparently, there are no software or driver available for Windows 7.
13 May 2011   #4
wazza
No other solution guys?
13 May 2011   #5
JOHN47
win7 home premium-64bit-SP1-IE9RTM
13 May 2011   #6
JOHN47
And you can also visit this site:
Recommends obtaining UAA Audio drivers from Microsoft for customers who have changed operating systems and are experiencing problems.
http://h10025.www1.hp.com/ewfrf/wc/s...n&dlc=en&cc=uk
14 May 2011   #7
wazza
Thanks. Checking them out right now.
14 May 2011   #8
JOHN47
wazza
please post back your findings to help others resolve their problems.
Thank you.
15 May 2011   #9
wazza
I really can't do anything with the links above.
Is there a way to just disable this quick touch thing? Well, for one thing, I'm sure it's internal damage though but..
15 May 2011   #10
JOHN47
I think that your sound card is overheating from lack of proper ventilation.
Check for that before doing anything else.
Good luck.
Computer is crashing.Problem signature: Problem Event Name: BlueScreen
Hi, My computer, Dell optiplex 760 Windows 7 Professional 32-bit, is crashing. The crashes often happen when i'm playing this game, League of legends, but it also crashes at random points while on a social media or gaming websites. How to fix? Help please.
BSOD Help and Support
Blurry Text problem, EDID and registry editing problem on an AMD card.
EDIT:I have found a solution, using a DVI to HDMI cable on an amd card will fix this problem, this thread can now die, hopefully someone else will find it if they have this problem. Basically, i know what the problem is, but not how to rectify it. My tv (Sceptre X235BV-FHD, a rebranded sony...
Graphic Cards
problem event name startup repair offline - slightly different problem
Hi, Hoping somebody can help with this problem which despite trawling through these very helpful forums & tutorials, I have been unable to resolve. I have tried to include all the information possible although I am relatively new to this field so my terminology is probably not completely...
General Discussion
Laptop Windows 7 Problem/Software/Hardware? Keyboard problem
Okay, right now I'm currently trying to find out whats wrong with a keyboard that is on a laptop, after the computer starts there are some script errors, I don't know exactly what they are but I ran combo fix without safe mode and restarted the scripts went away...and it started working after...
Hardware & Devices
Moving windows/icons down problem!! Move right/left/up - no problem
New system i7 3930K CPU Sabertooth X79 Mortherboard GeForce GTX690 GPU Intel 520 series SSD 32GB RAM Dell U2711 27" Monitor Win 7 Pro
General Discussion
Problem Reports and Solutions - Change Problem Reporting Settings
How to Change "Problem Reporting Settings" in Windows 7 and Windows 8 Sending problem reports to Microsoft helps Windows 7 and Windows 8 to check and identify problems and notify you about any found solutions. This tutorial will show you how to change the Problem Reporting Settings in...
Tutorials
