Looping Sound after crash
  1. Posts : 66
    Windows 7 Ultimate 64 bit
    Is there a way to turn off the looping sound i keep getting after my game crashes?
    I know it will go away if I turn my pc off but then I have to enter my 60 char pass at boot then at login then to load my hdds then i have to start all my programs up again and finaly start my game over .
    the dragon age .exe isnt running any more so im not sure what is cuasing this looping sound
  2. Posts : 8,608
    Windows 7 Ultimate 32bit SP1
    Did you look in 'sound' (from control panel)? .. click on the sounds tab.
  3. Posts : 66
    You mean in the mixer?
    theres only system sounds , speakers and steam but nothing else
  4. Posts : 8,608
    No, I mean click on the control panel, then click the sound icon, then click the sounds tab.
    Attached Thumbnails Attached Thumbnails Looping Sound after crash-sound-icon.jpg   Looping Sound after crash-sounds-tab.jpg
  5. Posts : 66
    all that does is show me my windows sound scheeme
    which is set to no sounds
  6. Posts : 1
    windows 7 x64
    Sound fix
    If your still looking for a solution to sound problem i found it myself
    Load up device manager and disable your sound device then re enable it and noise should be gone.
    Also disabling GX mode of driver (eax) may stop it accouring in the first place but have yet to test myself
