Windows 7: Problems with sound recording
28 May 2011   #1
SirHakke
Windows 7 Home Premium 64 bit
Hey everyone! I have a problem, which i have been struggling with for a long time.
Its simple. When i speak into a microphone, the sound quality is bad. Very bad.
When im on skype with my friends, they most of the time cant hear what im saying, because of stuttering and noisy sounds. When im trying to record sound via the sound recorder, the same thing happens. I have tried with many different headsets too, which works fine on other PC's.
I have a a Packard Bell EasyNote TJ66-843NC. I have heard that Packard Bell is very bad quality, which i believe in now, but if you know anything about how to solve this problem, please help me.
Btw, my microphone recording unit is Conexent High Definition Audio
28 May 2011   #2
JaidynM
I'm not sure that there's much you can do short of buying a new mic... If you were to buy one, what's your price range? I could try to find you a good, cheap one.
28 May 2011   #3
SirHakke
Well, i can try a new mic if so, but i dont think thats the problem.
I have a somewhat good mic, it worked great on my other PC, but it doesent work on this one. I was using my old PC for a period since this one was at a friend.
28 May 2011   #4
t-4-2
Windows 7 Home Premium 64-bit, SP1
Quote   Quote: Originally Posted by SirHakke View Post
I just bought this new computer one week ago, and I had this very similar problem.
This is how I fixed it .....
Plug in the mic > Start > Control Panel > Ease of Access > at Speach Recognition, select Set Up a microphone > select Desktop Microphone > Next > follow instructions there.
Hope it works for you.
28 May 2011   #5
SirHakke
Quote   Quote: Originally Posted by dhu View Post
I just did what you told me to do, but when i tried to chose Set up a microphone, it comes up with this error:
"Your current default speech engine does not support this action at this time"
How is that fixed?
28 May 2011   #6
JaidynM
Could you tell me what headset/mic you have? The majority of mic problems have to do with the actual quality of the headset, not the computer.
Direct Sound Recording?
So Microsoft made it a little harder to find how to record sound as it plays in real time, but now in 7 I can't figure out how to do it. Anyone have any idea? I have realtek audio sound.
sound recording
I have the following problem: I see only ONE Recording Device: Microphone, not Line In or Phone LIne. I have VM running and there I can seen ALL Recording Devices. I have the latest Software updates from ThinkVantage System Update. My configuration is as follows: IBM Thinkpad Lenovo Z61m...
[Recording] Stereo Mix Available, Sound Recording Not
Hello. I am EpicallyAWSM. Alright before I explain, I must tell you that I WAS able to record audio previously. I'm having a problem while recording audio with Fraps (a game video-recording software). Previously, I was unable to find the Stereo Mix at all, until I found the Drivers CD that...
recording sound in Win 7 64bit
Using the microphone the sound seems to be recoded to a wma file but there is no sound when I try to play it back. Can anybody help please?
Recording sound problem.
Hello, I have browsed through the forum for quite some time, and I did not find any solutions to this problem I have here. Well I bhought a new Computer with Windows 7 home premium 64-bit. An packard Bell EasyNote TJ62. With a soundcard Conexant high defination audio. Well when I click...
Recording Sound ??
Hi, Os: Windows 7 ultimate I want to record sound that comes from my speakers, I have right clicked the speaker icon on the taskbar, gone to recording devices, then right clicked to show disabled devices but there is no sound mixer. My sound card is: audio device: Creative X-Fi Audio Processor...
