Windows 7: Realtek HD Audio Manager Problem!
03 Jun 2011   #1
Glurft
So, I have Realtek HD Audio Manager installed, and the latest drivers. My sound is now working fine, but my microphone isn't even being picked up. I don't know what kind of problem this is, but I was looking for help. My motherboard with on-board sound is a ECS Elitegroup GeForce7050m-m. Thanks for the help
04 Jun 2011   #2
A Guy
Welcome to Seven Forums Glurft. If you have 2 channel sound, make sure it is set that way. Open Realtek HD Audio Manager, under the Audio I/O tab changed the 6 channel speaker settings to 2 channel. When it's set to 6 channel it uses the mic port (the pink one) as a center speaker and sub output. Also make sure if you are using the pink, back panel connector, that the disable front panel jack detection is checked. This is done through the Connector settings which is the little icon in top left hand corner of the window.
A Guy
04 Jun 2011   #3
rjay213
windows7 ultimate 32bit
i have problem with audio.
..i use windows7 ultimate OS when i finished installing win7 ultimate in the task bar it say's that No Audio output Device is installed i use speaker with 1 jack for green and for the plug...
..pls help me how to fix this problem...!
OS: windows 7 ultimate (32bit)
04 Jun 2011   #4
A Guy
Welcome to Seven Forums rjay213. Going to ask that you start your own thread, and someone will help you fix your problem. This thread is for Glurft and his particular problem. Just click on the New Thread button in upper left, and post your question. Give us your system specs and someone will help.
A Guy
05 Jun 2011   #5
Glurft
Thanks A Guy for the response, sorry I am responding late, as I had some other things to take care of. Anyway, I opened up Realtek HD Audio Manager, and I do not see an Audio I/O Tab. I don't know if I'm just being stupid, or if it really isn't there. Thanks for the help again
05 Jun 2011   #6
A Guy
05 Jun 2011   #7
Glurft
Currently, I have windows 7, and the first video you linked didn't have much help. It said to open miccal.exe under the windows folder that I do not have, and the Realtek setup for XP is a lot different than 7. The other two links talked about the 6 channel thing like you did, but I cannot find any of the stuff you or they are talking about. Another note, my mic is acting very strangely. When I unplug my headset (green port) my mic will work. When I plug it back in, the mic won't work, but sound will.
05 Jun 2011   #8
A Guy
Hoping someone using the manager will be along to assist you. In the mean time, see if the issues discussed in this thread apply:
Realtek HD Changing Jack output reassignments ( FIX )
A Guy
Difference between Realtek HD Audio Manager & Realtek HD Audio Driver
It's been a year since I migrated from Windows XP to Windows 7 which I downloaded Realtek HD Audio Manager R2.70 and audio has been working fine except the only issue it didn't come with 'Stereo Mix' preventing capability to record sound direct from the soundcard. It took me 14 months to restore...
Realtek HD Audio Manager not there/problem with headset
Hi everybody, since this is the first time using sevenforums I will try to make it readable. So I got sound card with 5.1 speakers on it, and headset sound will work if I put in jack into there where my speakers are, but If I put headset jack elsewhere it won't recognize the device and will do...
New Realtek HD Audio Manager Driver Problem with Microphone
Hello, I'm CrazyKilla So I recently got a new motherboard and because it's a new board, it came with it's own audio drivers, and my old ones were useless (obviously). I installed these new audio drivers and i found that it changed the look (and most likely the software itself) of the Realtek HD...
Realtek Audio HD Manager Equilizer Problem
When one of my friends built this computer for me, the Realtek Audio Manager was working flawlessly. It's been about a year since this computer was first built, and now I'm having troubles with the program. Usually I was able to adjust the sounds using the equalizer and the Room correction, now I...
Problem with realtek hd audio manager
Hello,everyone i have a problem with realtek hd audio manager.I installed the latest drivers and i dont have the audio manager i am working with Windows 7 Ultimate 64bit as the same i was working on my PC before,but now i am with laptop Acer TravelMate 5760G and i dont have the realtek manager,can...
Realtek HD Audio Manager and Realtek Audio Driver
Help. I recently did a clean install of Windows 7 64bit (on my HP Vista 32 machine). Life is grand! My problems started when I tried to listen to the microphone input through my speakers. The front microphone inputs did not work so I downlaed the Realtek HD Audio Drivers (recently updated) from...
