Windows 7: Realtek HD Audio Manager not in Control Panel
20 Jun 2011   #11
MultiCat
Quote   Quote: Originally Posted by Arc View Post
You may use Revo Uninstaller Freeware in advanced mode to delete all the leftover files during uninstallation .
After that you may try installing realtek again !
Realtek HD Audio Manager is not appearing in the Add or Remove Programs window so I can't do that.
20 Jun 2011   #12
Bongo
Win 7 Pro x64 / Win 10 Pro
You should use the driver from Mediion 1st MEDION UK - Product information it is not installing right it shows up in revo for me.
Jerry
21 Jun 2011   #13
MultiCat
Quote   Quote: Originally Posted by Bongo View Post
Jerry
That's the set of drivers I have been using.
21 Jun 2011   #14
Arc
Quote   Quote: Originally Posted by MultiCat View Post
It appears in Revo Uninstaller
21 Jun 2011   #15
MultiCat
Didn't appear in that either.
22 Jun 2011   #16
MultiCat
Now the Realtek HD Audio drivers are showing up in Add or Remove Programs and in Revo Uninstaller. Could this have something to do with my recent upgrade to 64bit?
22 Jun 2011   #17
seavixen32
Windows 7 Ultimate SP1 64-Bit
Probably. Windows 7's driver base is huge now so in most cases Device Manager is fully populated without any action on the user's part.
22 Jun 2011   #18
MultiCat
Quote   Quote: Originally Posted by seavixen32 View Post
But could that explain why I'm not able to access the HD Audio Manager?
22 Jun 2011   #19
seavixen32
I'm not sure, but it's quite possible.
You might want to uninstall your HD drivers using Revo and ask it to carry out a deep scan of your registry to remove any remnants and leftovers from previous installations, but do make sure you check carefully what you're deleting and backup the registry before you start.
Having done that you can then install Realtek's latest drivers to see whether you get your Audio Manager back.
22 Jun 2011   #20
MultiCat
I've done that and there's still no Audio Manager in the System Tray or the Control Panel.
Realtek Audio Control Panel wont open
Hello out there; first time on this forum, but first time I've hit a problem I can't seem to find a working solution for, so I hope someone can help. I've seen similar issues, and tried multiple solutions, but so far nothing has changed. I recently purchased a Dell XPS laptop running Windows7...
Difference between Realtek HD Audio Manager & Realtek HD Audio Driver
It's been a year since I migrated from Windows XP to Windows 7 which I downloaded Realtek HD Audio Manager R2.70 and audio has been working fine except the only issue it didn't come with 'Stereo Mix' preventing capability to record sound direct from the soundcard. It took me 14 months to restore...
NO SOUND and my Realtek HD Audio will not open from the control panel
Windows 7 86. I have NO SOUND and my Realtek HD Audio will not open from the control panel. I have reinstalled the drivers and used system image to recover but it has not solved the problem. I have used this system image before and it work perfect. I think it is a hardware problem but how can I...
Get rid of Control Panel,Device Manager,etc.. in desktop right-click
Hey Actually what happened is I got some .ico files and some regdit file that guy who gave it just wrote to copy it and give merge and i now get Control Panel,Device Manager,etc.. in my desktop right-click background so i need to know how to delete those items from my context menu of desktop Please...
Customization
Realtek HD Audio Manager and Realtek Audio Driver
Help. I recently did a clean install of Windows 7 64bit (on my HP Vista 32 machine). Life is grand! My problems started when I tried to listen to the microphone input through my speakers. The front microphone inputs did not work so I downlaed the Realtek HD Audio Drivers (recently updated) from...
