Windows 7: Realtek HD Audio Manager not in Control Panel
22 Jun 2011   #21
seavixen32
Windows 7 Ultimate SP1 64-Bit
A very long shot this.
Go back into Control Panel, click the View By drop-down list and choose Icon View then check if there's an icon for Realtek HD Audio in the alphabetical list.
There may be something in this user manual that will help: http://uk.ts.fujitsu.com/rl/services...-05%5B1%5D.pdf
22 Jun 2011   #22
seavixen32
I'm just wondering whether it's worth going into MSCONFIG and disabling Realtek Audio (if it shows) and just using the Windows sound system.
22 Jun 2011   #23
MultiCat
Quote   Quote: Originally Posted by seavixen32 View Post
I would, but I use Realtek HD Audio Manager to separate output channels. I have 2 jacks, one in the front and one in the back. I use the front ones for Skype (listening and talking) and the back one for my speakers (usually to listen to music through the speakers whilst talking on Skype through the headset).
I tried the other solution you mentioned but with no luck.
22 Jun 2011   #24
MultiCat
Just had another look in Device Manager and I've noticed that there's a item under Other Devices called "Audio Device on High Definition Audio Bus". When I click update drivers, it installed as "High Definition Audio Device". There's is now 4 "High Definition Audio Device"s as well as 1 "Realtek High Definition Audio".
Does this have any relevance?
22 Jun 2011   #25
seavixen32
Well, it proves that the Realtek drivers have been installed, but it doesn't explain why there's no icon in the Control Panel.
You could right-click the device in Device Manager and try to update the driver from there or uninstall the device, and then restart your computer to see whether Windows puts things right for you.
22 Jun 2011   #26
MultiCat
I'm afraid I've tried that too. :S Maybe I should re-install Windows...
22 Jun 2011   #27
seavixen32
In light of no fresh ideas that may be the best option although it somehow feels like a defeat when a re-install is all that's left.
22 Jun 2011   #28
MultiCat
Tell me about it. Haha.
22 Jun 2011   #29
seavixen32
If that's what you do decide we can keep the thread open so that you can let us know the outcome.
Just sorry we weren't able to find a solution for you.
22 Jun 2011   #30
MultiCat
I will do this later on and let you know how I get on.
Realtek Audio Control Panel wont open
Hello out there; first time on this forum, but first time I've hit a problem I can't seem to find a working solution for, so I hope someone can help. I've seen similar issues, and tried multiple solutions, but so far nothing has changed. I recently purchased a Dell XPS laptop running Windows7...
Difference between Realtek HD Audio Manager & Realtek HD Audio Driver
It's been a year since I migrated from Windows XP to Windows 7 which I downloaded Realtek HD Audio Manager R2.70 and audio has been working fine except the only issue it didn't come with 'Stereo Mix' preventing capability to record sound direct from the soundcard. It took me 14 months to restore...
NO SOUND and my Realtek HD Audio will not open from the control panel
Windows 7 86. I have NO SOUND and my Realtek HD Audio will not open from the control panel. I have reinstalled the drivers and used system image to recover but it has not solved the problem. I have used this system image before and it work perfect. I think it is a hardware problem but how can I...
Get rid of Control Panel,Device Manager,etc.. in desktop right-click
Hey Actually what happened is I got some .ico files and some regdit file that guy who gave it just wrote to copy it and give merge and i now get Control Panel,Device Manager,etc.. in my desktop right-click background so i need to know how to delete those items from my context menu of desktop Please...
Customization
Realtek HD Audio Manager and Realtek Audio Driver
Help. I recently did a clean install of Windows 7 64bit (on my HP Vista 32 machine). Life is grand! My problems started when I tried to listen to the microphone input through my speakers. The front microphone inputs did not work so I downlaed the Realtek HD Audio Drivers (recently updated) from...
