Weird audio problem
  1. Posts : 9
    Vista
    Weird audio problem
    Hi
    I am running Windows 7 7600.16385.090713-1255_x64
    I have a Creative X-FI X-Treme Music soundcard with Creatives beta Windows 7 driver installed.
    The problem just started today. I am listening to music and after a while the audio went strange. It seemed to fade and I could not hear the voices in it only the guitar and drums which also went quiter a bit.
    Does anyone know how I can resolve this?
  2. Posts : 28,845
    Win 8 Release candidate 8400
    audio prob
    srose said:
    Hi
    Hi and welcome
    First things first
    Could we get the rest of your hardware specs. OS (32 or 64).
    thanks
    Ken
  3. Posts : 9
    Vista
    Hi
    Spec:
    Win7 64Bit
    E6600 Core2Duo processor
    8800GTX Graphics
    ABIT IB9 Motherboard
    WD 320GB SATA2 Hard drive
  4. Posts : 3
    I'm having exactly the same problem you described.
    Did you manage to fix it?
  5. Posts : 83
    Windows 7600 x64 Ultimate Activated & 100% Genuine
    Try the Vista x64 driver and see if that makes a difference.
    » Download Creative Sound Blaster X-Fi XtremeMusic x64 2.09. 0007 sound card driver
  6. Posts : 9
    Vista
    Hi
    It turned out that the speakers were not connected properly. They just needed pushed in further and it worked fine.
  7. Posts : 83
  8. Posts : 3
    I'm running 32 bit Win 7.
    It's a really weird problem. I've got sound fading in and fading out on some files. Some Youtube videos just pay a really quiet bassline.
    The thing is windows sounds play fine over the top of this so it can't be a speaker problem.
    I've got a Creative X-Fi Xtreme card.
    Guess I'll just try another driver.
  9. Posts : 83
    Yes try the Vista driver.
  10. Posts : 3
    OK I worked it out
    Apparently the Creative Control panel works out what speakers you're using. It incorrectly guessed I was using 7.1 speakers.
    I changed it to headphone settings and it worked a charm
