Windows 7: Weird audio problem
19 Jul 2009   #1
srose
Vista
Weird audio problem
Hi
I am running Windows 7 7600.16385.090713-1255_x64
I have a Creative X-FI X-Treme Music soundcard with Creatives beta Windows 7 driver installed.
The problem just started today. I am listening to music and after a while the audio went strange. It seemed to fade and I could not hear the voices in it only the guitar and drums which also went quiter a bit.
Does anyone know how I can resolve this?
19 Jul 2009   #2
zigzag3143
Win 8 Release candidate 8400
audio prob
Quote   Quote: Originally Posted by srose View Post
Hi
Hi and welcome
First things first
Could we get the rest of your hardware specs. OS (32 or 64).
thanks
Ken
19 Jul 2009   #3
srose
Vista
Hi
Spec:
Win7 64Bit
E6600 Core2Duo processor
8800GTX Graphics
ABIT IB9 Motherboard
WD 320GB SATA2 Hard drive
09 Aug 2009   #4
Mr Brainz
I'm having exactly the same problem you described.
Did you manage to fix it?
09 Aug 2009   #5
Fisherking
Windows 7600 x64 Ultimate Activated & 100% Genuine
Try the Vista x64 driver and see if that makes a difference.
Download Creative Sound Blaster X-Fi XtremeMusic x64 2.09. 0007 sound card driver
09 Aug 2009   #6
srose
Vista
Hi
It turned out that the speakers were not connected properly. They just needed pushed in further and it worked fine.
09 Aug 2009   #7
Fisherking
09 Aug 2009   #8
Mr Brainz
I'm running 32 bit Win 7.
It's a really weird problem. I've got sound fading in and fading out on some files. Some Youtube videos just pay a really quiet bassline.
The thing is windows sounds play fine over the top of this so it can't be a speaker problem.
I've got a Creative X-Fi Xtreme card.
Guess I'll just try another driver.
09 Aug 2009   #9
Fisherking
Yes try the Vista driver.
10 Aug 2009   #10
Mr Brainz
OK I worked it out
Apparently the Creative Control panel works out what speakers you're using. It incorrectly guessed I was using 7.1 speakers.
I changed it to headphone settings and it worked a charm
 Weird audio problem
Transferring videos into my cellphone produces weird audio files
Hello, I'm having this issue where, whenever I copy/paste a video from the PC into my cellphone's MiniSD Card, it would produce weird unrelated audio files from my Musics folders. This is a result from an incredibly convoluted chain of problems that I've also been searching answers for since...
Music, Pictures & Video
weird weird graphic problem (3 screens setup)
Hello everyone, i'm having a weird problem in my setup, it's not a real problem but it's very annoying. i can't post a screenshot right now, but the situation is pretty simple: i have a "login button" (see attached example) floating on the left of my third screen. It's the same exact...
General Discussion
Weird behavior of Audio Service and Audio Endpoint Builder
Hi, Since this week, I'm experiencing strange behaviors of my sound installation. At times, the Windows Audio Service does not start. The "Audio Endpoint Builder" and the "Multimedia Class Scheduler" do have started. I tried some fixes, like changing the NDIS value (which led me to completely...
Weird Symptom ~ No Audio on BBC/1 HD if Switching from Another Channel
I use my PC as the basis of a Home Theatre with all my TV, DVD watching being projected via HDMI cable and audio via Sony amp. I'm running Windows 7 Home Premium 64 bit and have just upgraded my TV card to a TBS6280 DVB T/T2 Freeview HD Twin Tuner Card. Yesterday my TV region completed the Digital...
Media Center
Weird new audio problems running Windows 7
I've been running Windows 7 for close to a month now and it's been running flawlessly except until now. I've been having audio play back problems either from Windows Media Player or on Youtube. The sounds become slurry, distorted, laggy every few seconds. I don't quite understand what's causing...
