crackling sound while playing media
  1. Posts : 2
    windows 7 32 bit ultimate
    i hav a acpi x86 baseb pc. my hardware config are
    motherboard- asus p7h55mlx
    ram-4gb
    hardisk- hitachi 1tb
    sony dvd writer
    intel core i3 540 processor
    sound blaster 5.1 vx
    my os is win 7 ultimate 32-bit.
    my problem is that when i ply any media, a crackling sound appears. it is not frequent but it appears. also when i start my pc, the sound appears along with windows log on sound. also whenever i change the server while playing any video or audio the sound appears........can any one please suggest any solutions.........i donot know much about computers.....is it due to sound card ?........is some one getting similar problem ?
  2. Posts : 867
    XP, Vista, W7 64bit Home Premium
    Creative Worldwide Support > Sound Blaster 5.1 VX
    Latest driver download listed above - the general procedure for updating sound drivers is to uninstall the old driver firstly, reboot, then install the new driver - driver version listed : 1.04.0090
    If that doesnt work or you already have that driver you could enable your onboard audio and download the driver for it here :
    ASUSTeK Computer Inc. - Motherboards- ASUS P7H55-M LX
    Or search using the manual search for a vista 32 bit driver and try this if it doesnt install normally, and produces an error (we were doing this all the time with beta versions of w7 with a high sucess) :
    To install a driver/program in compatibility mode - right click the setup.exe file - click properties - click compatibility - check run in compatibility with vista - check run as administrator - leave the rest blank. Start setup.exe and install.
  3. Posts : 2
    thanx very much for ur concen whest. i downloaded the latest driver from asus website n now audio seems to be working fine. however there are three other folders named drivers, hotfix and nohotfix, in the zip file. i donot know what to do with the. can any one please tell
  4. Posts : 867
    You mean in the audio file from asus - dont worry you got it correct - they are probably for different operating systems or whatever, irrelevant in any case, you're up and running :).
