No sound after removing soundcard
  1. Posts : 5
    Hi all,
    I removed my emu 0404 soundcard after problems (it's known to have problems with W7).
    My sound (with onboard) was working before installing the Emu.
    What have I done wrong?
    http://i30.tinypic.com/10dsk7k.jpg
  2. Posts : 419
    Windows 7 Build 7600 64bit/Ubuntu/Leopard
    did you remove it after or before the installation of windows 7
  3. Posts : 2,651
    W7 RTM Ultimate x64
    Have you Tried setting your speakers to the default playback device?
  4. Posts : 5
    First I installed windows 7 without soundcard.
    My sound stuttert so I installed an Emu 0404
    Then sound stopped with the Emu 0404
    Then I removed the Emu.
    I am sure it's a settings problem.
  5. Posts : 419
    was vista installed before or xp.
  6. Posts : 2,651
    W7 RTM Ultimate x64
    Set speakers to Default Playback Device?!?!
  7. Posts : 5
    No, it was a clean windows 7 install
    I did: no sound
  8. Posts : 6,305
    Hi Goldenben, welcome to the forums.
    The best thing to do IMO is to uninstall all sound devices in 'Device Manager' then scan for hardware changes. This will force Windows to re-configure and if need be, download from Windows Update and install the sound card. This will also set all defaults to the newly installed (old ) sound device.
    Hope this helps :)
  9. Posts : 5
    And we have lift off...
    Thanx Shark. That did the trick.
  10. Posts : 6,305
    That's great news, and you're welcome
