pls do I have 5.1 channel audio output?
hello, just purchased Acer AX3950-U3022, trying to determine if 5.1 channel audio is put out. It's a refurb from SenecaData; two requests in to seneca data tech support ; so far, they cannot tell me. Other than one HDMI output, the only audio output is what looks like standard green analog jack; one on rear, one on front panel; plus blue and pink on rear. front has a mic input jack.
This pc is replacement upgrade for original purchase Acer AX3910, which did have separate channel audio output jacks on back panel; 6 of them. i believe it also had s/pdif; and HDMI output. But imaging problem meant they had to repair all of this model, and they replaced original with upgraded ax3950, assuring me it had all features and more of original AX3910 i bought; and i specifically asked about 5.1 channel audio out, that tech support rep said yes it had it.
the AX3950 has upgrades; 6 GB ram instead of 4; i3-550 dual core processor instead of E5800; hyperthreading; but 3910 has HDCP support, 3950 doesn't list yes or no; both models have one pciexpress x1 and x16 slot.
Realtek HD Audio Manager on board; if 5.1 audio out is selected, it shows Analog outputs but hovering cursor over three rear jacks shows front speaker out, rear speaker out, center/subwoofer out. If stereo audio is selected, same three jacks just show standard settings of mic, line in, and audio out.
there is not product manual for either pc! just a 30 page setup manual.
please can you advise me what the AX3950 is capable of?
If i use HDMI output, can i also use the speaker jack without switching?
I suppose i could connect HDMI output to my HDTV, then HDTV optical output to my AV receiver, then i'll have 5.1 channel sound through the av receiver?
i'm confused.
I asked the second Seneca tech support if a sound card was necessary; he said he didn't think the slots would work for that; he promised to research and get back to me in a few days. But seems to me he should already know the answer to this.
thanks for any advice!
system info attached;
