Intel IDT Audio Driver will not install
Page 1 of 3 123 LastLast
  1. Posts : 2
    Windows 7 beta x64
    I am trying to install the latest audio driver for the Intel® Desktop Board DG965SS under Windows 7 Beta x64.
    IntelĀ® Desktop Board DG965SSĀ Audio: IDT* 92XX Driver
    However, when it goes to configure the driver I get the error:
    Device Object not present, restart the system and run setup again.
    I get this running the installer in normal and compatibility modes.
    Any help on how to get around this error, or a point in the right direction for the correct driver would be greatly appreciated. Merci beaucoup !
  2. Posts : 1
    Windows 7 Beta 1 7000 , Windows Vista, Windows XP(all 32-bit)
    When i checked the Hardware manager, Windows 7 installed mine as a High Definition Audio Device, But i haven't tried to get Surround sound yet
  3. Posts : 2
    Windows 7 beta x64
    Yeh, thats what it did for mine as well...which is fine to just hear sound.
    However, I need Stereo Mix, Line In, Mic, etc. that requires an audio driver
    I tried the RealTek driver, but that did nothing, as expected. :[
  4. Posts : 1
    Solution
    Well, i found a relatively easy fix....
    Step 1:
    Ok, first you need to copy the sound driver files
    off the cd that came with your motherboard into any folder on your computer.
    For example, "D:\Sound\IDT"
    Step 2:
    Second, navigate to the folder you pasted the drivers in.
    Then go to IDT, then WDM and lastly Vista.
    Step 3:
    Next, open both ---_WRT_---_--_--.INI files in notepad.
    For example mine were called, "ECS_WRT_202_G2_DY.INI" and "ECS_WRT_206_G2_DY.INI"
    Under the [Models] category remove all occurences of "&SUBSYS_--------"
    For example it should read,"
    HDAUDIO\FUNC_01&VEN_8384&DEV_7682=this
    HDAUDIO\FUNC_01&VEN_8384&DEV_7683=this
    HDAUDIO\FUNC_01&VEN_8384&DEV_7680=this
    HDAUDIO\FUNC_01&VEN_8384&DEV_7683=this"
    Now save both files and start the copied installer, and it should work.
  5. Posts : 1
    Win7 64
    I registered for the forum just to say thanks T11230. Your tip worked, thanks!
  6. Posts : 2
    Windows 7 Ultimate / Windows 8 Build
    thanks T11230
  7. Posts : 1
    windows 7
    I also registered for the forum to say thanks T11230, and with your help make the IDT audio drivers work for the Intel DP965LT:
    In the [Vista] folder of the decompressed driver ( I used AUD_allOS_D20001.0x_PV_IDTGUI_v105_Legacy.exe), look for a file "Stwrt.ini", then edit as T11230 instructions: delete [&subsys_######] but leave the "=" and next characters, example: HDAUDIO\FUNC_01&VEN_8384&DEV_7680=I3.INI.
    Then reset the PC AND reconfigure your audio settings because in the first boot you are not going to get any sound (don't panic).
  8. Posts : 2
    window 7
    i also register to say thanks man.....
    people who r still unable to configure there 5.1 system...
    1) Repeat the steps told by t11230 and fyrigoyeno
    2)then configure ur windows sound panel (control panel-->sound->manage audio device-->select the speker icon-->then click on configure -->set to 5.1 thats all)
  9. Posts : 1
    I also register to say thanks "T11230"
    I had no more sound since I migrated my HP Pavillon dv7 2130 from Vista to Windows 7. No Media application worked anymore.
    Following "T11230" advices, I've modified "WRT_M*_*.INI" files located at "C:\Program Files\IDT\WDM".
    Now everything is working fine.
    Many thanks !
    Hopping Microsoft will fix this problem !
    Mick
  10. Posts : 3
    Windows Vista Ultimate x64
    I tried T11230`s and others instructions and still nothing... still playing on 2 stereo chanels...
    I have windows vista ultimate x64 on my HP Pavilion dv5-1101en, and i have the same problem with outputing 5.1 sound.
    In my IDT High Definition Audio Driver i erased the "&SUBSYS_--------" phrase from
    stwrt64.ini
    stwrt.ini
    WRT_M4-1.ini
    WRT_M4-2.INI
    WRT_M4-3.INI
    WRT_M4-4.INI
    WRT_M8-2.INI
    I tried multiple combination for almost 10 hours... I became desperate... I spent 400 euros on my 5.1 samsung sound system and all I can hear is sterea sound...
    Please help me!
