Intel IDT Audio Driver will not install
  1. Posts : 2
    window 7
    send me ur mail id.... i will forward u the file.... only replace that file ... and after installation ....go to control planel to configure ur 5.1...
       #12
    The HP does not use the Intel IDT drivers. Most of the HP's I've worked on lately have been using ASUS motherboards. If HP does not have drivers check the Retail IDT drivers.
    How are you connecting to the Samsung Sound System? Via S/PDIF (digital)? or some type of analog connection? Many PC's only have two channel output on the Digital link, not 5.1 or 7.1.
  3. Posts : 3
    Windows Vista Ultimate x64
    my e-mail is Removed by Dwarf - please use the PM system if you wish to give your email address to another member. Do not include it in the open forums.
    thanks a lot!
  4. Posts : 3
       #14
    I am connecting my sound system via standard stereo cable (3.5mm jack at one head, ard RCA at the other head). Is the only way that i can connect.
  5. Posts : 8,135
       #15
    If you are connecting via the GREEN speaker out jack that is ONLY two channel stereo, you can't get 5.1 out of that.
  6. Posts : 1
    Windows 7 64 bit
       #16
    Great job
    What an awesome find. Gateway was no help ,,,in fact no one could helo and was just about take my clone drive and put it back on Vista 64 becasue of the stupid drivers for IDT. All I had were the restore disks from gateway which show everything as APP 1032222 whatever ,,,so I had to muddle through 40 or so to find the IDTin App002022 which was some 2007 version. I checked every .INI deleting the &sub and everything in btw the =. First time intalled and worked ever since. Have the gateway p 6860FX laptop I was thinking screwed bc Gateway is so bad about providing support for OEM drivers. I even tried using the IDT windows 7 driver put out for intel. Such I simple fix and Gateway or IDT was just dumfounded as what to do.
    Fantastic Job
  7. hem
    win 7 32bit
       #17
    A big thanks to you T11230. After searching for hours to enable my front panel audio jack which is by default not working in windows 7, i came across this post and promptly disable the default MS Audio driver and installed the previous IDT audio device driver which was working perfectly for my XP for front audio panel. And now after installing as per your instruction, again my front panel audio jack is started to work. So again lots of thanks dear....
  8. hem
    win 7 32bit
       #18
    Problem solved...
  9. Posts : 15
    Windows 7 Ultimate x64 Version 6.1 (Build 7600)
       #19
    I installed windows 7 four months ago and waited for an official driver package from IDT, and i was about to give up when I chanced upon this thread! Now I followed T11230's instructions and have front panel support again!! Thank you soooo much T11230!!
  10. Posts : 4
    Seven
       #20
    OMG !!!!!....THANK YOU SO MUCH !!!! I did it !!!....
    I was so sad because I couldn't use mi microphone, but now it's excelent!!!!....
    I LOVE YOU !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
