No Sound on computer?
  1. Posts : 6
    Windows 7 64 bit
    Hi everyone.
    I have a problem with the sound on my computer. At startup there's no sound, and there's a red cross across the symbol down in the right corner. When i click on the icon, the troubleshooter starts, and after 30 seconds or so, there's sound again. What can I do, to get sound immediately, when I start my computer, so I don't have to wait all the time?
  2. Posts : 290
    Windows 7 Ultimate 64Bit (SP 1)
    Can you fill in your system specs please and confirm what driver version you have installed.
    Regards
    UKMedia
  3. Posts : 6
    Windows 7 64 bit
    Of course. I use Windows 7, 64 bit.
  4. Posts : 9,582
    Windows 8.1 Pro RTM x64
    A bit more information than that, please. We need to know what audio device you have installed.
    To make things easier for filling in your specs, try the utility mentioned in this Tutorial. It even has a link to your specs, so that you can fill them in from the information provided.
    System Info - See Your System Specs
  5. Posts : 6
    Windows 7 64 bit
    Should be done now :)
    Hope I have filled out all you need to know now =)
  6. Posts : 6,075
    Windows 7 Professional 64 bit
    This link hopefully should take you to a page on sony's website for driver downloads for your model of laptop.
    I would suggest downloading and installing the audio driver.
    VAIO : Sony Europe
  7. Posts : 6
    Windows 7 64 bit
    I have tried the link now, but unfortunately it doesn't seem to solve the problem?
  8. Posts : 6
    Windows 7 64 bit
    Any other ideas?
  9. Posts : 290
    Can you confirm what driver version you are using for your sound card?
    Regards
    UKMedia
  10. Posts : 6
    Windows 7 64 bit
    I am using Realtek High Definition Audio version 6.0.1.5886. I have tried to update is several times, but it seems like it is already up to date, so I don't think that's the problem?
