sure thing. the help would be great seeing as i have exhausted all my options.
Its is Realtek ALC888 7.1 HD integrated into an ABIT I-N73HD
you could try these from dell:
http://ftp.us.dell.com/audio/Realtek...01_R176166.exe
same model, this way worked for me once. good luck!
I'm using the 2.22 drivers (Vista x64 version) directly downloaded from Realtek's site. Works like a champ. I've read that you should download the .zip version. Just in case you downloaded the .exe version that could be worth a distant try.
I have the same computer system as the OP. I've installed the latest Realtek Device drivers for Vista 32/64 bit from the website, and the driver installs fine, and the computer recognizes it, however sound refuses to play from the speakers. When I wear my headphones I can faintly hear the sound, but nowhere near a satisfactory level, and that's at 100% volume on all counts. My sound card is Realtek ALC 882.
I tried it with 64 bit Windows 7, and since that didn't work, I tried 32-bit to see if it would make and difference, which it didn't, so currently, I'm using 32-bit Windows 7.
Any help would be greatly appreciated.
I have Realtek 880 High Definition Audio on a Asus MotherBoard. My problems look like projectd24 . Do you have an ATI HD graphic card with integrated HDMI , because my windows used the HDMI sound as default and didn't reconized the REALTEK . Afther several hour of search I went into my Bios in the advanced option and I put my integrated audio to ENABLE instead of AUTO and windows automaticly install my REALTEK audio driver and sound work great! :P
OK, I think my problem is the same. It is NOT solved BUT............
If I plug the headphone into the MIKE input I get a popup that asks what device I plugged in. If I select HEADPHONE, everything works like it did in XP -- except that the headphone is plugged into the mike port.
is yours the same?????????
definitely and issue.
thanks to aper3 for the recommendation. I was working on an HP media center edition. By changing the audio from auto to enabled, Windows 7 picked up the hardware and installed the appropriate software for the machine. Many thanks.
Regards,
Paul
Paul M. Muhlbach, A+, CNA, MCSE, MCT
Calgary, AB
a follow up on my issue with the headphone jack not working.
I decided it HAD to be a h/w issue so I pulled everything apart determined to find it this time. (I looked once before but didn't find anything).
AH HA!!!!!
The headphone jack switch was not working. After looking all over for a replacement jack and not finding it, I took it apart (the plastic on this one was not glued) and "tweaked" the switch mechanism by bending the moving arm slightly.
Everything is fine now. This procedure is recommended only for those mechanically inclined. I also had to remove the part from the pc board.
