sound problem
  1. Posts : 135
    Windows 7 64bit
    sound problem
    i do not know if there is a post about this but i will ask myself
    so .. my problem:
    i usually run everything on speakers but sometimes i want to switch to headphones
    if the game is running and i switch to headphones or the other way around i have no sound and i must restart the game .. why ? how can i fix this
    and this happens on every game i play :|
  2. Posts : 2,578
    Vista 64 bit and 32 bit (SP2)
    I believe that in many cases once you've switched to headphones, in order to get back to your system's speakers, you have to either start the game again or worse, reboot your system.
  3. Posts : 968
    It could be caused by a full-screen application block by your firewall suite..For instance my Norton Suite blocks applications from changing parameters while in game mode or entering full screen applications..
  4. Posts : 135
    Windows 7 64bit
    i do not have any kind of anti virus anti spyware detection or protection ... only the standard that i get from windows 7 updates
    so ... what do i do ? suggestions ?
    and so far i didnt need to restart pc to get my sound back ..
  5. Posts : 135
    Windows 7 64bit
    thanks a lot ... i guess no solution
  6. Posts : 1,996
    Windows 7 Home Premium 64 bit
    If you have the P5K board, the U.S. boards use the Realtek codec.
    If your board is using the same codec, you can download the Realtek software from here Realtek, if you haven't already.
    The software gives a jack detection pop-up whenever it detects that your headphones have been plugged in. By pressing OK to the pop-up, you should have sound. The sound shouldn't be disabled because you're using a game, but it could happen.
    Let us know!
  7. Posts : 135
    Windows 7 64bit
    i cant download it
    how do i check what series is my p5k ? i used to have that program but not anymore
  8. Posts : 135
    Windows 7 64bit
    i cant believe this
    ANY suggestions on what i can do ? its very STUPID this bug glitch or w/e it is and its pissing me off that i have to restart the game so i can get sound back -.-
