Realtek HD Audio Non Working Rear Speakers
Page 1 of 3 123 LastLast
  1. Posts : 16
    Hello Everyone ,
    I recently searching in forums to get solved my problem , but no one fix that issue . I Read many threads so i need the fix because i'm sick to see another posts from fools that they don't know anything about software's or hardware's.
    So My Problem Is :
    Yesterday i format my pc again , before i format my pc my audio was working fine . after the format i found an issue that my rear speakers don't work . I Check Other Speakers To See If My Speakers Broked but nothing . i connected my speakers to other pc and they working fine . I installed the drivers and everything .
    Thanks.
  2. Posts : 1,996
    Windows 7 Home Premium 64 bit
    Have you checked the levels? Sometimes they get reduced to zero.
    Use the slider on the side to scroll.
  3. Posts : 16
    Yeap :) Already Check Them
  4. Posts : 1,996
    What do you have selected here?
  5. Posts : 16
    Quadraphonic
  6. Posts : 1,996
    When you click next, is "Surround speakers" checked.
    It should be.
  7. Posts : 16
    yeap it checked :) the 3 icon of speakers are working only the TOP - RIGHT won't work. :/
  8. Posts : 1,996
    Realtek
    Well, if you've already installed the software and drivers from the link,
    I can't think of anything else. If I do I'll post it.
  9. Posts : 16
    alright thanks :) anyone ? other suggestions ?
  10. Posts : 1,996
    One last thing.
    Unplug all your outputs. Restart the PC.
    Plug in each jack one at a time and let the software go through the jack detection process.
