Realtek HD Audio Non Working Rear Speakers
Page 3 of 3 FirstFirst 123
  1. Posts : 1,996
    Windows 7 Home Premium 64 bit
       #21
    Sometimes a driver re-installation can fix the problem.
    Use the Realtek software to uninstall what's already there.
    Restart. Windows will load the generic sound driver.
    Install the Realtek software.
    If that doesn't fix it, then I'm out of ideas. :)
  2. Posts : 16
       #22
    So Im I :P
  3. Posts : 3
    64bit windows 7
       #23
    My rear speaker tests out ok but the player does not play music on the rear.
    The windows program speaker test is ok on each speaker. Even the realtek speaker tests are successful.. but the PLayer is the problem. The player will not play on the rear. I even tried other players but none work on the rear. So something is wrong with the Windows Media player in Windows 7.
    Each speaker will play a Sound if I do a speaker test in Win7 or Realtek application.. but the Windows media player is not playing music on the rear.
  4. Posts : 2
    Windows 7 x64 and windows xp home
       #24
    Music doesnt play out rear
    I got you covered I tried everything and was at my whits end as well
    .could not get the rear speakers to play rear under normal audio.... speaker tests worked ...
    all i needed.... the Realtek driver and...
    Creative Sound Blaster X-Fi MB5 Application
    got it here at dell
    https://dl.dell.com/FOLDER03380544M/..._1.0.3_A02.EXE
