Another HDMI Audio Problem
  1. Posts : 5
    Windows 7, 32 bit
    Hi everyone,
    I know this topic is a popular one, I've done enough searches on google to figure out I'm not alone with this problem, but still, after a few years, I still can't find the answer. I realise there is a similar thread active right now but my problem is a bit different in that I don't have the option of HDMI in my playback devices at all.
    I'm using
    Samsung R480 laptop
    Intel Core i5
    nVidia GeForce GT 330M
    High Definition Audio Device (EDIT: when I was updating the drivers Realtek uninstalled itself, this should read Realtek High Definition Audio)
    This is a familiar story by now BUT: when I first got my computer my HDMI video and sound worked fine hooked up to my Samsung Plasma. I recall having some problems when I first tried to hook it up, but I figured it out (somehow, this was a couple years ago) and I'm 75% sure it had to do with the drivers. Then I went away for a year, came home and the audio is gone. I have updated all my drivers (I think) and Samsung Update Plus doesn't have anything for me. "Speakers" are the only choice in my playback devices menu and I have show disabled devices checked.
    Apologies, I know this comes up often, but I'm at the end of my rope.
  2. Posts : 968
    What shows up in device manager? Does it show the HDMI device and does it show it's working properly?
    Attached Thumbnails Attached Thumbnails Another HDMI Audio Problem-8-21-2011-5-05-52-pm.png
  3. Posts : 5
    Windows 7, 32 bit
    Thanks for the quick response.
    Under sound, video and game controllers I have:
    Bluetooth handsfree audio
    It says the device is working properly.
  4. Posts : 670
    Windows 7 Pro 64bit build 7601 SP1
    Did you make sure the cable is good? What about any settings on the tv itself too?
  5. Posts : 5
    Windows 7, 32 bit
    Yep cable is fine. Can't see anything in the tv settings that look off. Source is definitely correct.
  6. Posts : 1,996
    Windows 7 Home Premium 64 bit
    From what you've mentioned, you don't seem to have an HDMI audio driver installed.
    You should see an Nvidia High Definition Audio Device in the device manager.
    Your HDMI audio driver would be included in the Nvidia driver package.
    It could be as simple as re-installing your Nvidia drivers or maybe not, but you should try that first.
  7. Posts : 5
    Windows 7, 32 bit
    Thanks p5bdkw. I tried doing a clean install for the NVIDIA drivers, the video installed but the audio did not (just said "not installed"), so I assume my audio isn't going through there (???). Pretty sure I'm not delusional though, it was definitely working before I left home.
  8. Posts : 1,996
    Sometimes a system restore may fix the problem. You may have the option of a Samsung restore, as well as a Windows 7 restore.
    You can also try using the original drivers from the Samsung support website.
    Be sure to select your correct model and model code.
    Samsung
  9. Posts : 5
    Windows 7, 32 bit
    You get the prize p5bdkw!
    I have the Canadian version, so went to the Canadian website and downloaded the first "HDMI" driver. Turned out to be HDMI Audio for NVIDIA and bingo my HDMI option has returned. No idea how it got removed. Thanks so much!
