No Sound on Sony Vaio
  1. Posts : 3
    Windows 7 Ultimate 32-Bit
    I upgraded from Vista and now I have no sound. Anyone know how to fix this?
  2. Posts : 1
    Win 7
    the best solution is why you dont trying to access sony webpage to download the latest driver for your product. Or give the model here.
  3. Posts : 28,845
    Win 8 Release candidate 8400
    Hi redpymid and welcome to sevenforums
    We would be a lot more helpful if you filled in your system specs.
    thanks
    Ken
  4. Posts : 3
    My model # is VGN-FS940. I've already gone to the sony site to download the latest driver but in the drop down box for OS Windows 7 isn't an option.
    Also, I don't really that smart with computers so I don't know what most of my specs and what not are. ;>.>
  5. Posts : 3
    Hey, I was able to get the sound fixed so no worries, thanks for your guys help.
  6. Posts : 1
    window 7
    what did you do... mines is show that its installed but im not getting any sound... but if i plug up headset i can hear thru them or ex-speaker works...
  7. Posts : 1
    windows 7
    hello. i have the same problem even if i plug something i have a vaio vgn-b150fp. i think i had a realtek audio driver before changing os. but im not sure... i have installed all the drivers from sony and nothing...
  8. Posts : 7
    Same problem on a Vaio VGN-FS660. Tried uninstalling, updating, everything. Sony said will not release any drivers until Windows 7 is officially released. If anyone figures out this issue, please post the solution. I've got a few more ideas, hopefully something will work.
  9. Posts : 7
    IT WORKS!!!
    I was looking though the rest of this forum and found the sticky thread below. I downloaded the driver and installed it. After a re-start, my sound works perfectly. I would recommend trying it, what is the worst that can happen, your sound will stop working??? Good luck! Now I have to try to fix my video....
    Latest Realtek HD Audio Driver Version
  10. Posts : 5
    windows 7
    Sony does not support Windows 7. I went online to look for realtek driver update and was able to get the new drivers that work with windows 7.
