Windows 7 - No sound problem.
  1. Posts : 12
    Windows 7 Ultimate 32bit.
    seth500 said:
    seavixen32 said:
    Have you checked your sound settings in the Control Panel?
    Attachment 173398
    Try right clicking in a blank area and show disabled devices and see if it's been disabled in the screenshot..
    I have and nothing shows up.
    And I quite sure it's not a built in sound card. How can I tell?
  2. Posts : 968
    Well you can pull the panel off the side of your computer and see where your lead is plugging into and see if the sound card is a removable sound card if it is try reseating it in the slot with the computer shut down of course..
  3. Posts : 12
    Alright, I'll give it a shot.
  4. Posts : 12
       #14
    I opened it up, and it seems to be built in to the motherboard. Now what?
  5. Posts : 7,730
    Windows 7 Ultimate SP1 64-Bit
       #15
    Then you may have to consider that your motherboard may have been damaged by the power outage.
    Damage can occur in this scenario if your power supply and your computer aren't protected by a surge protector.
  6. Posts : 968
    It looks as though you may have a damaged audio output device on the motherboard. If you can get yourself a sound card for pci slot if you have empty slots on your board and install a sound card and go from there. Probably not what you wanted to hear but it's less expensive than a new motherboard providing that the outage didn't do anymore damage to it.
  7. Posts : 12
       #17
    So, I may have to buy a new motherboard?
  8. Posts : 968
    Or just a sound card but who knows what the power outage did to the mobo and your PSU..
  9. Posts : 25,847
       #19
    To the OP. If you don't have surge protector I would also suggest getting one.
  10. Posts : 12
       #20
    Alright, thanks. I'll talk to my computer buddies. One of my friends built his computer so he'll know what to do. These answers defiantly beat Microsoft's answer.."We can most surely fix this problem you are having sir, we will transfer you to our technicians but you will need to pay $59.99." No joke.
