No audio output device installed
  1. Posts : 36
    MS Windows 7 Home Premium 32-bit SP1
    I bought a generic computer. It had windows vista installed and it used to display a message that No audio output device is installed . I recently installed windows 7 home premium 32 bit on it but it still says the same thing. I went to properties of it and found following error message.This device cannot start. (Code 10).
    System specifications are
    manufacturer EMACHINES
    SYSTEM MODEL T5010
    TYPE X86 BASED PC
    BIOS VERSION INTEL CORP. AG91510J.15A.0816.2005.0214.1818, 14/02/2005
    SMBIOS VERSION 2.3
    Hardware Abstraction Layer version= 6.1.7600.16385
    Sound Device Name High defintion audi device
    Manufacturer Microsoft
    status error
    PNP device id HDAUDIO\FUNC_01&VEN_10EC&DEV_0880&SUBSYS_08600000&REV-0900\4&....
    DRIVER C\windows32\drivers\hdaudio.sys(6.1.7600.16385, 297.00 KB (304,128...
    I downloaded and installed the intel chipset driver and then the RealTek driver from manufacturer website but that didn’t solve the problem.
    If I buy a sound card from a computer store, perhaps I will also get CD for driver installation with it. If I put sound card in my system and install driver, will the sound function start working. thanks for the help
  2. Posts : 414
    win7 ultimate 32bit
    Sound is possibly disabled in the BIOS.
    enter BIOS and check under advanced chipset features
  3. Posts : 10,200
    sdraza,
    Win 7 is not eXPired. If the sound card you buy is not some off-the-wall el-cheapo card, then MS will automatically install the needed drivers.
    I'd like for you to help us by doing following, precisely as written:
    UPDATE YOUR SEVENFORUMS SYSTEM SPECS
    User CP (3rd item in the top menu bar) |
    Your Profile (left-hand column, Edit System Spec |
    To gather info, use
    Speccy - System Information - Free Download
    or SIW or the System Info tool,
    Use System Info to see your System Specs
    Please add the word laptop or desktop or netbook to the
    “system manufacturer” block.
    Provide full windows version info, for example:
    MS Windows 7 Ultimate 64-bit SP1
    Use the “Other Info” block for Optical Reader,
    Mouse, touchpad, wifi adapter, speakers, monitor, etc
    Scroll down and click on the SAVE CHANGES button.
  4. Posts : 36
    karlsnooks said:
    sdraza,
    To gather info, use
    Operating System
    Intel Pentium 4 519K
    Prescott 90nm Technology
    RAM
    1.00 GB Dual-Channel DDR @ 106MHz (2.5-3-3-7)
    Intel Corporation D915GAG 65 °C
    Graphics
    SyncMaster (1400x1050@60Hz)
    Intel(R) 82915G/GV/910GL Express Chipset Family
    313GB Seagate ST3320613AS ATA Device (SATA) 42 °C
    Optical Drives
    HL-DT-ST CD-RW GCE-8483B ATA Device
    Audio
    High Definition Audio Device
  5. Posts : 10,200
    1 GB of ram is under what I call the practical minimum of 2 GB.
    No sound in Windows
    Open the Hardware and Devices troubleshooter
  6. Posts : 36
    No sound in Windows
    I went to both links and ran fix it but problem is not solved. Now perhaps the only option is to buy a new sound card and install it. Right? thanks
  7. Posts : 10,200
    Definitely a "sound" idea.
