Microphone not working, is enabled but wont pick up audio
  1. Posts : 17
    Seven 64
    I've had this problem ever since i built the PC and latest drivers don't seem to fix it.
    Previously on Win XP, i had to disable a line in to get the mic to work, however those options don't appear to be available on Win 7
    i have an EVGA nForce 680i SLi motherboard, and running Win7 64bit Home with onboard sound.
    i have updated the latest motherboard and realtek drivers, however cannot find a control panel for the microphone/audio other than windows own. (previously on XP realtek had a very poor UI/software to adjust the settings as well as in windows)
    any ideas/help would be great
    ta
    Chris
  2. Posts : 968
    Go to your sound icon down by the clock and right click on it and select sound and then recording devices. Right click in a blank area of the screen there and select show disabled devices and post a screen shot of it if you would.
  3. Posts : 1,996
    Windows 7 Home Premium 64 bit
    Have you used Configure and Properties to make adjustments?
    They're greyed out until you select Microphone.
  4. Posts : 17
    Seven 64
    yup, set to 100% + 30db boost
  5. Posts : 968
    Who makes the microphone? Is it a usb type like I have cause it appears that your computer isn't recognizing it.
    Attached Thumbnails Attached Thumbnails Microphone not working, is enabled but wont pick up audio-9-3-2011-3-12-17-pm.png
  6. Posts : 17
    Seven 64
    it is on my Sennheiser PC 350 headset, worked perfectly on Win XP, and never worked since moving over to Win 7
  7. Posts : 17
    Seven 64
    when "listen to this device" is true, i get static through the speakers, if that helps at all?
  8. Posts : 968
    Very nice headphones I must say. I'm wondering since these are a combination headset/microphone if there is not some software that you need to run them. I have looking all over the net to see if these need that even the on their site but that doesn't seem to be the case. I would ask them to see if they are compatible with Windows 7:
    Sennheiser USA - Service & Support
    Tell them the issue your having and see what they say..
  9. Posts : 17
    Seven 64
    Thanks, a quick google and noticed another guy in particular has the same issue
  10. Posts : 17
    Seven 64
    seems to be a common problem, just tried my brothers 4.99 headset and works fine
    thanks for all the help
    Chris
