problems with realtek hd audio
  1. Posts : 28
    7 Ultimate 64/XP 32bit/XP 64bit/Google OS
    I have installed the realtek audio driver, but with the driver the sound in crackly, but when i uninstall it the sound is good but i can't use no headphones for my laptop. The realtek driver was the latest.
    Please i need some help and really fast
  2. Posts : 3,322
    Windows 8.1 Pro x64
    Latest Realtek drivers worked fine for me 7.
    Uninstall the drivers and download Driver Sweeper from Guru3D, install it and run it as admin and clean the Realtek drivers.
    Try installing the new drivers again and see if they're better.
  3. Posts : 28
    Still the same and i tried newer and older drivers
  4. Lee
    Win 7 Pro x64, VM Win XP, Win7 Pro Sandbox, Kubuntu 11
    Welcome to the Forums pilliboy12,
    If your laptop came with Vista installed, and a driver's disk was included, then try using the vista drivers. If no driver's disk then go to the manufacturer's web site and down load the driver. Can't promise it will work, but just maybe.
  5. LFB
    Windows7 Enterprise SP1 x64 (Technet)
    What Build are you using?
    Some old "Leaked" builds have problems with HD Audio...
  6. Posts : 28
    i am using R2.29
    For Lee
    My laptop game without any OS and i have tried drivers from the CD and from manufacor home page, they just woun't install.
    This is the error
    Attached Thumbnails Attached Thumbnails problems with realtek hd audio-untitled.png
  7. Posts : 623
    vista x64/ win 7 x64
    pilliboy12 said:
    i am using R2.29
    For Lee
    This is the error
    The installer checks for the Vista version, finds an unknown one and rightly tells you so.
    Which Realtek chipset do you have?
  8. Posts : 28
    i have alc883
  9. Posts : 623
    pilliboy12 said:
    i have alc883
    Google: Results 1 - 10 of about 665,000 for alc883 windows 7 issues.
    You're not alone i guess
  10. Posts : 28
    yeah i now
    But i thinked something out i write some **** what my friend seed and it worked but i isn't the best.
