Problem with realtek hd audio manager
  1. Posts : 6
    Windows 7 Ultimate 64bit
    Hello,everyone i have a problem with realtek hd audio manager.I installed the latest drivers and i dont have the audio manager i am working with Windows 7 Ultimate 64bit as the same i was working on my PC before,but now i am with laptop Acer TravelMate 5760G and i dont have the realtek manager,can someone tell why and how can i fix it because i really need it,or from where i can download it.This is the description of my sound card if it will be helpful for you.
    Audio Adapter Conexant Unknown @ Intel Cougar Point PCH - High Definition Audio Controller
    Thanks a lot i hope someone will respone or give me an advice that could help me solving this problem. :):)
  2. Posts : 11,424
    CS9090,
    Welcome to SF. Do you see something on the Realtek site here that is worth trying? Note that they highly recommend using the downloads via the mfgr's. site, have you exhausted the downloads available there as well?
    http://www.realtek.com.tw/downloads/...&GetDown=false
    http://www.support.acer.com/us/en/pr...x?modelId=3628
  3. Posts : 6
    Thanks for the respone :)
  4. Posts : 6
    This did not help i downloaded all of these i installed them and nothing again
  5. Posts : 11,424
    Bummer, slammed at the moment. I hope others will come and assist, I'll check in later.
  6. Posts : 6
    Ok I think the problem is hiding at the fact that my sound card is Conexant.So I installed the drivers for Conexant but there is no audio manager thats bad ... i tried with the SandBox audio program but i did not like it the way it sounds,its important for me to have a program like this because i listen music trough stereo amplifier and stereo and before i was using this Realtek sound manager and the sound was just perfect now .. its like something is missing and it does not sounds that great like before.Sorry if a i made mistakes but my English is not very good.If you can tell me what other good program i can use instead realtek it will be great.Thank you ! :)
  7. Posts : 1,996
    Windows 7 Home Premium 64 bit
    Someone correct me if I'm wrong, but I don't think that the Realtek software/drivers will work with the Conexant audio. Once you install the drivers/software by using Setup, you should see the Conexant device show up in your device manager. If an audio manager is installed when using "Setup" and it doesn't show up in the notification area, you can usually access the application by going to the Conexant program folder. Right click on the application and add it to the quick launch.
    You mentioned that you installed the software......whether it be Realtek or Conexant, the driver that is compatible for your system will show up in the device manager. That's the device, you should look for in the program folder to launch the program's audio manager.
  8. Posts : 1,996
    The Conexant software is probably limited in what you can do with it. I wouldn't expect much in terms of sound enhancements, like the Realtek software.
  9. Posts : 6
    Ok thanks about all the info but i have installed it i searched at the folder i installed it i searched in Devices and Printers i did not found it there but i found it in the folder of the downloaded file which i unrared,and when i start it,it just pops out for a second one little black window like the /cmd window and after that it closes and when i click the right button i cant add it to the quick launch there is no option like this can you please tell me how to do it step by step
  10. Posts : 1,996
    There's probably no audio manager included within the software.
    The pictures I posted are of the Conexant Audio Message Service.
    I doubt there are any advanced sound applications, like with Realtek.
