Some mp3's won't play
  1. Posts : 5
    Hope someone can help me.
    I recently bought a Ibuypower computer w/ Windows 7 64 bit. I imported my music library and a huge part of my mp3's just wont play... I revised the old codec of my XP computer and noticed that the codec SIPRO LAB TELECOM AUDIO CODEC is not on the Windows 7 audio codecs list.
    Anyone has an idea????
  2. Posts : 14,606
    you could try adding a codec pack,
    sharks007 pack is generally the recommended one on 7forums
    Shark007's FREE Codec solutions - Windows 7 codecs
    shark007 is also a forum member here so the support for his codecs is very good.
    what happens when you try to play an mp3 do you get a message of any kind?
  3. Posts : 31,250
    MP3 playback is native in win7 so it could be something to do with the transfer of the files that is actually causing the issue.
    I would check the security permissions on the files concerned and make sure that your actual user has access to read and execute the files, Also check the Everyone Group
      My Computers
  4. Posts : 5
    I installed the shark codec pack but the SIRPO codec is not included. The security seems ok. Any other ideas?
  5. Posts : 31,250
    Surprised that Shark does not cover what you need, as it's never let me down
    A quick search on google led me to this site which purports to supply a free codec for SIRPO
    Do not know the pack so cannot actually recommend it but it is proof that support does exist for the codec.
    If you decide to install this pack make sure you remove the Shark pack first
    http://www.free-codecs.com/download/...odecs_pack.htm
      My Computers
  6. Posts : 8,135
    That is some specialized Codec.
    I easily found that codec by doing a google search.
    Here is one that says it has that codec
  7. Posts : 5
    Thanks for the help. Hope it works. If not a standard mp3... how can i make it work on W?
  8. Posts : 31,250
    This looks like an old codec that is in the process of becoming obsolete, it was included in early versions of XP but later withdrawn, you may be able to get one of the codecs linked to working with win7 but If possible I would look at converting the files to a current format, if you can find a suitable converter.
    another possible source
    Sipro Lab Telecom ACELP.net - Sipro Lab Telecom ACELP.net codec - areecodec.com
      My Computers
  9. Posts : 5
    Now that i remember, the files that won't play were converted from sony sonicstage format to mp3. I'm downloding the program just to see if this solve the problem. Thanks for the ace mega pack sugestion, but the sipro codes wasn't the problem. I'f this don't work, I'll throw this damn machine out of da window and buy a mac. FOR GOD SAKE.... I'M JUST TRYING TO HEAR SOME MUSIC. WHY MICROSOFT MAKE IT SO HARD ON SIMPLE THINGS!!!!!
  10. Posts : 5
    Thanks for the help guys!!!! Intalling sonicstage solve the problem. This program has his own encoder.
