Mp3
Hello ,
I have downloaded a song from internet but when i am trying to play it on my phone it shows error "unsupported file " .but in the details of the song the format is Mp3 , Please help me
Hello ,
Your MP3 file may be corrupt, download a new copy
Hello ,
I have downloaded about 10 copy of that song from different sources .
Does your phone play other mp3 files OK?
You could try to convert the mp3 to WAV or another format and then convert it back to mp3.
10 sources means from 10 different sites , I have also converted that song to WAV then into Mp3 but its not playing
Could you help me ?
1. Do other mp3s play on your mobile?
2. Does this mp3 play on your computer?
Hello ,
Other Mp3 are Playing on my mobile ,yeah this Mp3 is running on my computer
is it write protected , meaning it will only play on the pc it was downloaded to.
if you have a smart phone then try download it directly to your phone.
Some mp3 files with errors ( not conforming to MPEG standards) may not play in some players.
You may download MP3 Validator from Free MP3 Validator - check and repair mp3 files, it can also fix mp2 MPEG audio files .
Extract it to a folder and run mp3val-frontend.exe. Add your MP3 file, right-click and "Scan selected file for errors". If there are errors, "Repair selected files".
The screenshot:
By default, the program is supposed to back up the original as yyy.bak in the same mp3 folder.
Since I have had no problems, I have not used it. Hope it resolves your issue. As a matter of abundant caution, back up the original in some other location, till you become familiar with the program.
Try and report. Good luck.
