Audiodg.exe doesn't loads in Windows 7
Mysteriously, the audiodg.exe service seems not to run in the active processes as a result of which I could get sound. When I try to run the process through new task option , it loads up and immediately disappears.
What do I do? Other audio services and everything seems fine. It used to run on same machine with the process on.
EDIT :I tried sfc scan, and it found no problems with file.
