5.1 Sound doesnt work at Realtek High Definition Audio Device
  1. Posts : 49
    Windows 7 Ultimate 64-bit SP1
    Hello, Some time ago i was tried to connect my 5.1 creative speakers to my laptop and when i wass connecting one by one the cables windows 7 asked me what speakers it will play ( Rear, Front, Center) but now i try to connect them again and it does not ask me that ... and only 2 speakers and sub is playing know ... and cant find what is the problem and when i go to Sound and press at the speakers that is working configure there is not a choice of 5.1 as it was before ... What is the Problem know please can anyone help me ?
  2. Posts : 740
    Do you have the VIA HD Audio Deck installed with your sound driver. It may be in the control panel, systray or not installed. It should be compatible with your realtek onboard audio. I usually have more luck using this to configure my speaker setup than windows as in may versions it supports jack switching.
  3. Posts : 49
    Its not installed where do i find it ?
  4. Posts : 740
    Doh, dont listen to me, realtek and VIA are both very different cards, they are just both so common I overlooked the obvious. For the Realtek Mixer try here (the realtek version of the same thing) Realtek
  5. Posts : 6,879
    Win 7 Ultimate x64
    If you laptop is like the majority of them made then there is no problem. Reason being is that it only has a single jack for connecting speakers/headphones, and you cannot get 5.1 sound from a single jack it takes three; one for the front speakers, one for the rears, and one for the center/sub.
  6. Posts : 49
    No ok i Just Fixed all ! I just gone to Dell site And dowloaded drivers for my onboard Sound car ! and its all as was before ! but thanks for your answers ... SIGMATEL Driver for SIGMATEL STAC 92XX C-Major HD Audio Version: 6.10.0.5866, A03
  7. Posts : 49
    Hey i have another Question ! there is no Ajustment of Level of rear or front Speakers.. How can i Ajust them Because the rear is very low and all i hear is from the front and center ..
  8. Posts : 11,424
    I don't believe you'll be able to as the rears are just being averaged off the content of the mains as it's not a true 5.1 set up.
  9. Posts : 49
    Hmm i think and Believe that there is a way to do it ... but dont know how anyone else with some idea on how i adjust the rear speakers ?
  10. Posts : 6,879
    Win 7 Ultimate x64
    How many audio jacks are on your laptop? It takes 3 of them (usually color coded green, black and orange) to get 5.1 sound from an analogue connection, anything other than that and it is nothing more than stereo upmixed by the speaker set itself with no way to control any levels via software.
    Would help to know the make and model of the laptop, as well as the model of Logitech speakers.
