strange boing noise
  1. Posts : 37
    windows 7 x64 Home Premium
    strange boing noise
    Hi i keep getting this strange boing noise on my laptop, so i have it on mute all the time and i took it off mute and it still doing it i dont even have to touch anything on my laptop for it to do it it does it randomly so i havent a clue as what it can be, any help would be great thanks
  2. Posts : 740
    could be Malware, software you have installed, or an error message that's failing to appear. Fill out your system specs and post a screen shot of your startup items as listed in msconfig.
  3. Posts : 37
    i added some more on my specs but not sure how to get the rest of the info
  4. Posts : 740
    type msinfo32 into the start menu, then expand software environment at the side, then select startup programs. then click file at the top and export to a text file, then when posting here, click the paperclip and upload that text file and insert it in your post.
  5. Posts : 37
    here it is
    strange boing noise Attached Files
  6. Posts : 740
    Cant see anything suspicious there, try running Malware Bytes as your only av is MSE (which is good in itself against major threats).
  7. Posts : 37
    ok thanks will get that now...
    one other question my laptop gets pretyy hot and makes a lot of noise any idea what it could be ?? im on my laptop a hell of alot a day though so ??
    edit:my sig not showing up ??
  8. Posts : 740
    Signatures are limited by size, after you upload an image you need to add the sigpic tag to the free text area of your sig.
    Edit: laptops get hot, the noise and heat are likely caused by fans and heatsink getting clogged with dust, this reduces the cooling efficiency and aerodynamics, this results in max fan speed and more heat. I used an AMD laptop that reached 91 degrees C last week and thats only 6months old.
    See http://www.hwinfo.com/ for your temps if you are really interested.
  9. Posts : 37
    ok thanks
    just did a quick scan with malwarebyts and found nothing
  10. Posts : 740
    How frequent is the noise and does it sound the same as any other system sounds or completely different? How long has it been there?
    If it's frequent, open the mixer and see if the sound activity is shown, and what application it is shown against.
