strange boing noise
Page 2 of 2 FirstFirst 12
  1. Posts : 4,049
    Sounds
    Are you sure it isn't the "Device Connect", "Device Disconnect" or "Device Failed to Connect" sound?
    Try this:
    • Right click on the "Speakers" icon in your "Notification Area".
    • Click on "Sounds".
    Any item in the "Program Events:" list that has a speaker symbol by it, has a sound set for that event.
    You can hear the sound by clicking on the "Test" button.
    If you want to change the sound, click on the "Browse" button.
    If you want to turn the sound off, click on the "Sounds:" drop down list and choose "(None)".
  2. Posts : 37
    windows 7 x64 Home Premium
       #12
    the noise is realy load sometimes when its been on for a wile its been like this for prob a few months but only realy thought about it about a month ago it gets realy hot were the fan is as well i was thinking it could be clogged and i tryed to access the fan but didnt get very far lol so not sure how to get to it
    @lehnerus 2000 just did that and the sound isnt one of them ??
    edit: and when i just turned my computer on it loaded to black screen and it to a few mins for it to start on my desktop im just thinking of re installing windows for the 6th time lol, i had problems ever since i got windows updates and they crashed my computer alot so i desabled the updates
  3. Posts : 4,049
    Does the noise happen at random, or does it only happen after your PC has been running for a while?
    Perhaps the heat problem, is causing the sound card/chip to misbehave.
  4. Posts : 37
       #14
    it just does randomly, iv left the sound off mute now so see if it does it but my laptop has only been on for a bit so its still cool,
  5. Posts : 4,049
       #15
    You could temporarily disable the sound card/chip (using the "Device Manager").
    If the strange sound occurs, it shouldn't be Windows fault.
  6. Posts : 740
    If the heat was the problem I would suggest it's a bios alarm warning about the temperature, but then I dont think the mute would stop it because the bios uses the on board system beeper. Not sure if many laptops have these, they dont usually have user changeable bios settings for things like temperature alarm and shutdown (like desktops do), but this doesn't mean there aren't fixed setting for such things.
    Another thoughts is: What is the battery condition like?
    If the battery isn't charging this could trigger the low battery alarm even when it's plugged in.
  7. Posts : 37
       #17
    the battery doesnt stay on long its ment to last for 3 hrs but only lasts about 30 mins to 1hr so got to keep pluging it in
